jimschulz
I'm finishing up my Explorer EFI swap and am needing to connect to 12V keyed power. I spoke with Gary a while back and he said he preferred to get the keyed power directly off the ignition with a spade connector, however my ignition switch has no exposed spade connectors. Has anyone pulled the keyed power from the ignition switch? And if so, how did you accomplish it. I was thinking I could try and disconnect the 904 wire (Green-Red Stripe) from the back of the ignition which used to go to the voltage regulator. I don't believe it will be used anymore.
Thanks in Advance.
Thanks in Advance.
