MY EFI install is almost complete-just a few tweaks left. Based on the Ford tech manual for my donor vehicle (89 Crown Vic), the O2 sensors get +12v (grey/yellow wire) directly from the ignition switch when the key is in the "run" position. Since the Bronco ignition switch doesn't have multiple poles like the Crown Vic switch, I am using the same "run" +12v source for ignition, O2 sensors, and everything else that is powered when key is turned to "run". My voltmeter is reading off this circuit as well. Since the O2 sensors are heated (requiring the +12v "run" source), the O2 sensors put a load on the cicuit that is dropping the voltage to approx 8.5v when the key is turned to "run". When I unplugged the O2 sensors, the voltmeter showed +12v with key in "run".
Am I totally messing this up somehow or is this normal for an EFI conversion?
Can I take out the "heater" (+12v) from the O2 sensors? Will the computer recognize that the O2 sensors are not heated?
Is there a +12v source in the Ford EFI harness that is only supplied when the engine is actually running versus key turned to "run"?
Would the fuel pump +12v (after relay/before inertia switch) be a good place to tap into +12v for the o2 sensor heat since that wire is hot for 2 seconds then not powered until the engine is running?
Thanks for any helpful input.
