EFI 408 Stroker motor
ransil
What is the recipe for the EFI set up on a 408.
Computer, injectors ect???
bax
Old Member
Just bore a 400 out 30 over and add a FAST injection system. your done.
Contact your local dyno shop. I will guess (depending on your total combonation) a 90mm lightening MAF and 42lb injectors (maybe 30 or 36). The 42's are fairly easy to come by, they are stock in late model lightenings.
Mustang A9 computer and wiring. Lighening or other 5.8 mustang style intake.
To the casual it will look like a warmed up 5.0 mustang motor. Look a little harder and they will see the 351 block. They won't know stroker unless you tell them.
mountainview68
yet to be determined
427W EFI
Edelbrock Victor EFI Upper and Lower
42lb injectors with Trick Flow fuel rails
85mm Pro M Meter
80mm Accufab Throttle Body
255 LPH high volume fuel pump
A9L computer custom chiped
Ryan McCormick wiring harness
All OEM ford sensors
broncomaster
Edgewood,Wa
427W EFI
85mm Pro M Meter
That is my dream stroker
Looks like Kryptonite wouldn't even slow that thing down.
R
ransil
This Motor will be going in a truck, so can the stock intake system be used?
Also looking for drive ability not ball out running.
Madgyver
Bronco Madman
427W EFI
85mm Pro M Meter
Nice!!
I like how you relocated the core support..
mountainview68
Mine runs fine as a driver. The 427 is built for torque. Keep your foot out of it and you are fine. Peak horsepower is at 5300 and peak torque around 4200, can't remember exactly. It is going back on the dyno in a few weeks since I fixed the tranny, so I should know more. I suppose you could run a stock intake but it will kill the engine. These things need air!!!! I think a lightning intake is the very least you can run. Exhaust is something to consider also. What trans are you going to run??
Devin
Bronco Kineticist
427W EFI
85mm Pro M Meter
If you wouldn't mind sharing, how much did that bad-boy set you back?
PhantomEB
Calgary, Alberta
OH oh, my pants are getttin tight.. PLEASE dont let me end up over at my bud's place, we just might end up trying to start up talks of building me a 427....
mountainview68
I almost feel guilty telling you, I got the entire engine assembled from a guy who ran out of money for $3500. The heads were to small so I replaced the AFR 185s with the vic jr's. Cost me about $1000 extra. All the fuel injection stuff is mostly ebay, used or used new, maybe about $2000 So with tuning and stuff probably around $6000-$7000, maybe a little more. It has been spread out over a few years as all out projects are.
mountainview68
Trans is going to be a C-6
Good choice, beef that baby up!!! I have broke my C6 twice. Ford racing shorty headers fit nice with the C6 and are resonably priced. They will sacrifice some power as they are only 1 5/8" primaries, not alot of other choices other than custom headers. I am running a MAC 1 3/4" header. Had to do quite a bit of modifying and I really don't like them all that much, but building custom headers is not CHEAP!!!
