The history of the accumulator...
Early EFI vehicles added one inline withthe 2 pump system That litle black thingy on the drivers side frame with 4 fittings on it. This was so the old style carb gas tanks could continue to be used.
Newer vehicles withthe in-tank pumps still have an accululater of sorts. It is the design of the gas tank.
Why the accumulater?
With old carbed engines the fuel pump could grab a gulp of air and pass it no problem. The fuel bowls would keep gas going into the engine for a little bit even if the pickup was sucking air bubbles.
EFI engines don't have fuel bowls. Any blip in the fuel delivery drops the pressur to nothing. Since the EFI requires fuel to be pressurized in order for it to squirt out the injectors, if the pressure drops off so does the fuel delivery.
Now if you drive around gently, flat roads, always keep lots of gas in the tank, then no an accumulater isn't needed. You will never get into a situation hat you need one.
but if you ever get the truck at funny angles, hard turns, dudden stops or starts, run low on fuel. Then you should look at an accumulator.
Nothing sucks more then needing power and having gas slosh away from the pickup in the tank and fuel pressure drop to zero and the engine stalls.
