I have tried the search and so far not coming up with anything.
A little about my set up 351w ford lighning upper and lower plenums. motorsport 70 mm throttle body ,24 pound injectors , summit 70 mm MAF summit pro billet TFI distributor Rjm harness A9S computer msd streetfire tfi coil. I have checked fuel pressure and is steady 37pounds at idle and 42 WOT. with it running at idle it is fine if you bring it up to 2200 or higher it will get a surge like it lost power for a sec. then comes right back up. I put a volt meter on my main power wire off the battery and it stays right at 14.1 volts even when it surges. Is there a way to check tfi coil wires for steady spark or volts??? Any ideas are greatly appreciated. Dave
