Thanks for the information Todd. Do you have any preference on fuel lines? I see WH offers braided lines, and BC offers a hard line kit?
There are hard line kits and it's hard to go wrong with them from a longevity/durability standpoint. You'll use some rubber lines for transitions at various points depending on how your truck is set up.
For soft lines, I imagine that regular parts stores still sell rubber EFI line (30R9 rated)- I haven't shopped for any for decades so I don't know for sure. Back when I did my 5.0 conversion back in '97, I bought it from Napa and 28 years later, my truck is still plumbed with 90% of that. The secret, in my opinion, is to route it properly - away from heat/abrasion, proper bend radii, proper stress relief, proper fittings, proper hose clamps (use EFI hose clamps) and support it properly in its runs (I use Adel clamps and T&B ty-raps for much of mine). The insides will probably degrade before something happens on the exterior. I removed a section of mine a few years ago and inspected it under a high-power scope at work and it still looked pristine.
If you're going to use rubber hose, I'd use the barricade hoses that
@Broncobowsher mentioned - specifically Gates Barricade hose or Holley Vapor Guard. They both have liner layers to deal with crummy fuel. Holley also sells -6 AN fittings designed for the hose along with either the proper hose clamps or Oetiker clamps that can be crimped.
The PTFE-lined (make sure it's non-conductive) braided hose is also a good option. Assuming all the proper precautions taken above, I think it could be considered a lifetime installation on a typical rig. The fittings are a little more challenging to assemble than say...Vapor Guard fittings, but still not too bad. A PTFE-lined braided hose with an exterior liner (Fragola is one vendor that makes such a thing) would add even more durability.
My truck is so oddball and non-standard that it will probably always have flex lines in it - and that's a not bad thing if done properly.
Todd Z.
