EFI guru's pelase assist
bronco italiano
I have a 5.0 with an AOD trans but a manual trans ecm EEC-IV (A9L). The official ford mustang 5.0 technical reference book states a manual ecm will not work with an AOD. Is there a resource for buying a ford ECM like the x3z? Thanks, BI
surfer-b
You need the A9P or the C3W these are for the 89-93 mustang 5.0, however I have run the A9L with the auto and had no probs.
scsm76
Shaver Lake, CA
The A9L will work with the AOD, it would be better to have a auto computer but they will both work. I found my ECU on Ebay. A used A9P shouldn't be hard to find and A9L's are pretty easy to sell.
jr
Mililani, Hawaii
The reason is that the AOD transmission has a starting system connection in which, when the key is ON, in the START position, 12 volts are going to pin 30 in the ECU connector plug. You can put the auto ECU in a manual transmission, since it doesn't miss the signal. If you install a manual trans ECU in an AOD application, that 12 volt power will fry the maual ECU. You can also use 8LF, A9P, A9T, C3W.
I have a couple i'm willing to sell if you are interested.
Joel
744x4
Taylors,SC
One is looking for a Clutch interlock (A9L and goes to ground) and the other is looking for a Neutral Safety Switch (A9P and runs 12v through it).The A9P has a more aggressive Timing curve and is actually a better computer for that fact. I have a A9L with a C-4 so mine was a easy install.
Duke Nukem
Simi Valley
The best computers for your application are the following: A9M, A9P, C3W, C3W1, A9T, 8LF
Just go ebay shopping and you should be able to find one. If you shop around usually you can grab one for under $100.
All of the above are mustang mass air EEC computers for automatic transmission. There are those who have successfully used a manual tranny EEC with an automatic transmission and vice-versa. The most noticeable difference between the two is that the auto tranny computers drop the idle more slowly when you let off the throttle. According to the FordFuelInjection web site there is no major difference between most of the various mass air computers so don't get hung up on having, say, an A9P versus an C3W. I've run different computers with my mass air system and can say that all the ones I've tried pretty much run the same.
You should review the following list of EEC computers:
http://www.fordfuelinjection.com/?p=17
bronko69er
EB Addict
Renton, WA
[quick hijack]
Which if any computer will work best with a manual tranny and not require the use of a VSS.
[/hijack] sorry
scsm76
Shaver Lake, CA
[quick hijack]
[/hijack] sorry
They all will run without the VSS, but with out it connected they tend to die when stopping or braking from my experience. They may have some other ill symptoms that I have not experienced.
bronko69er
EB Addict
Renton, WA
I guess I should have been more specific.
I knew about that problem but,
Do all of them behave this way?
Are there any ways around this other than using a VSS?
Duke Nukem
Simi Valley
Why the reluctance to run a VSS? It is a fairly inexpensive install and plugs right into your transfer case. As was said, you can run without one but might run into some stalling problems with sudden stops. Some people seem to run fine without one so you can try it that way first and add one later if it doesn't seem to work right. I don't know a way around using a VSS other than just not installing one and taking your chances that it will run OK without it.
bronko69er
EB Addict
Renton, WA
Not really reluctant just trying to understand which componoents are necessary and which are optional (like the EGR system).
I'll stop hijacking now and move my questions to my EFI thread.
Huskerbronco
Lincoln, Nebraska
I have a A9P that I'm not using as my Bronco has a manual and my parts Mustang was an auto. If you want I will swap you straight across for your A9L. Computer came out of a running 91 Mustang GT.
PM me if your interested.
B
bronco italiano
Ryan I bought your harness via BCB some time ago. I just want to make sure I do not mess anything up. If your harness can correct this issue that the ford mustang 5.0 book is saying then I am good to go? Thanks, BI
Ryan
Lansing, MI
The start signal burning up the ECM problem is only with the Ford EFI harnesses.
If you have my harness it will work with any combo.
http://rjminjectiontech.com/harness_manual.pdf
Read step 19 on page 7
