EFI Guru's
oldskool
Denver
I have a 351W w/Lightning upper & lower. Everything was running good and it started to run retarded. Getting Code's 44, 94, 33
Need help, getting truck ready for Stampede, need it running good so I can go have some fun.
Thank you
broncnaz
Might want to expand upon your setup. basically what computer are you running, are you running a EGR setup? any other mods to the motor? and what exactly do you mean by runs retarded? Ect
00gyrhed
Yea, does it feel like the timing is being retarded or is it running simple mindedly?
oldskool
oldskool
Denver
I have A9L EEC. When I say retarded, it simply running so rough like it whats to die, but it doesn't it says running.
The other day I tried to install a new tach, and when I turned truck on to test it it starting running this way, I removed tach and truck ran perfect like it was before.
Then one day later sitting at a red light, truck just started to run rough, then like a good bronco owner would do, I drove it like I stole it to the next light and it started running fine. then once I got home it ran like crap.
Viperwolf1
electron whisperer
A bad tach can cause ignition problems and it can be intermittent.
Still need more info on the EFI setup. Injector size, MAF used, harness, etc. Might want to run a KOER test also.
u10072
Did you do a good job on all your soldered connections and the grounds can cause issues.
