Efi hard start and rough idle
Ghost Pony
Bossier City
I'm having trouble with my injected 351 on start up. Ryan's harness, 90 mustang based, i have to start it 3 or 4times to make it run. I've noticed that if i take the air filter off it seems to do a lot better. With the air filter on, (once it starts) the rpm's drop and then rev up again while it is trying to warm up. Replaced the iac, but this had minimal effect.
I think i should be able to turn the key once and have it idle perfectly with efi, but that's not what i'm getting.
Thanks guys
70_Steve
Old Guy
How about starting with the usual questions.
Codes??? (KOEO, CM and KOER)
Have you verified the IAB (IAC) operation (unplug it while it's idling)?
Fuel rail pressure?
What EEC and how do you have pin 30 connected?
Ghost Pony
Ghost Pony
Bossier City
codes 81 82 85 84 80
It doesn't seem to change anything when I unplug it.
I'm going to have to check fuel pressure again, but i believe it is ok. I had it checked at a buddy's shop a couple of weeks ago.
A9L PIN 30 IS PLUGGED INTO MANUAL
What gets me is the engine is choking down so easily.
70_Steve
Old Guy
I assume 81 82 85 84 are the KOEO codes. But where did 80 come from? Did you run the cylinder balance test? Code 80 is Cylinder #8 failed the CB test.
That may be an issue. With the key on and IAB unplugged, see if you have between 3.0 and 12.0 volts (according to FFI.com) on one of the wires.
ransil
what is your timing set at?
did you try cycling the key 3 or 4 times before starting to prime the fuel system, if you do this does it help or no change?
Did you set your idle per the step by step procedure?
Ghost Pony
Ghost Pony
Bossier City
12 volts at the iac.
Cycled the key 3 or 4 times. No change.
I'm not familiar with the cylinder balance test or the step by step proceedure to set the idle.
Timing is set correctly
ransil
Idle reset procedure.
1. Unplug the SPOUT connector, start the engine and let it reach operating temperature, then check and, if necessary, adjust base timing.
2. Shut the engine down, then stick a .050-inch feeler gauge between the throttle stop screw and lever.
3. Disconnect the IAC solenoid connector, shift the transmission into Park, start the engine and allow it to stabilize for approximately two minutes.
4. Adjust the throttle stop screw as necessary to obtain an idle speed of 675 rpm 25 rpm.
5. Shut the engine down once again, then disconnect the battery for a minimum of five minutes to allow the PCM's keep-alive memory to time out.
6. Remove the feeler gauge, reconnect the SPOUT and IAC solenoid connectors, then start the engine and allow it to stabilize for two minutes.
7. Goose the throttle several times, let the engine return to idle, then make sure the base idle speed remains in spec.
8.Drive it for 15 minutes making frequent stops.
Ghost Pony
Ghost Pony
Bossier City
New codes
Ran the code tester again. This time i got a couple of new codes.
81 82 85 84 10 66 96
10, 66 and 96 are all new.
Whats puzzling is 80 is now gone.
The thing that stands out is 66. Which i believe is maf sensor. I assume i should replace it. Might this be causing my problem?
70_Steve
Old Guy
So, are you using a code reader? The 10 might be the seperator blink between KOEO and CM codes.
What's really puzzling is that the 80 was there to begin with.
What MAF are you using?
Does your A9L have anything done to it?
What injectors are you using?
70_Steve
Old Guy
how can you count something that doesn't flash?
Same way you can spend money you don't have!!!:cool:
It's a timing thing... If you run the cylinder balance test, all the results have a zero on the end. What you really see is the first digit of the code, then a little longer than normal time 'till the next code.
Ghost Pony
Ghost Pony
Bossier City
Ford maf sensor off of an 89 mustang.
I do not believe the a9l has anything done to it, although i can't be sure.
24lb injectors. I've been wondering if i should go to 18lbs? I got the 24's with all the other efi stuff from a buddy who was converting to a carb.
I'm using a code reader. I don't have the patience for counting blinks!
What do you think about the 66 code?
70_Steve
Old Guy
If you've got access to a set of 19 lb injectors, I'd try them. I believe that's what the A9L expects stock. When the engine is cold, it's running off lookup tables. Takes the air flow, and fires the injectors per the table. If you've got bigger injectors, you'll have more fuel going in than you're supposed to. That's also why I asked about the MAF.
The 66 code is a CM code, which happens while the engine is running. It means the MAF put out a lower than expected signal, as in, too low an air flow. Could have been during an idle stumble. I'd clear the CM codes and see if it comes back.
To quickly clear the CM codes:
1. Setup the system to run a KOEO self-test.
2. Turn Ignition On.
3. As soon as the codes start to flash, disconnect the STI jumper wire.
ransil
Don't start swapping parts until you understand what is going on and can prove that is the part to change.
Get rid of all codes first then modify stuff, in the end you may need to visit a dyno and get a chip burned.
Ghost Pony
Ghost Pony
Bossier City
Ok, guys I really appreciate the help! What should be my next step? I do have a set of 19 lb injectors that I collected from the wrecking yard after the efi install.
What should I do next? Put in the injectors? Do idle set proceedure? Or cyl. test?
ransil
idle set procedure and cylinder balance test..
both are free and only take a little bit of time.
70_Steve
Old Guy
Try the idle set procedure. If it's running badly then it may be difficult to do. I'd be more interested in the KOER codes, but while you're running the test, may as well do the Cylinder balance test.
marty
massapequa, n.y.
i know this sounds like it might be crazy but do you have all your injector plugs hooked to the right injectors. it's like crossing a spark plug wire if not. they are not batch fired but are sequential. like your ignition.
You stated the MAF is '89 mustang. The sensor looks like it could be but what is the housing? That does not look correct. It looks too large.
What I am thinking...
You got a housing that holds the sensor, but larger. Now the MAF calibrations is wrong. The sensor reads a tiny portion of the air, then calculates airflow based on the size of the housing and knowing how much goes aroud the sensor vs. how much went through. Since you oversized the housing, less air boes through the sampling part and you gt a lower voltage reading. Thus your low MAF code. This throws off the air/fuel mix.
A real '89 MAF (sensor, housing, complete, non-molested, non-ported, original) and a set of 19Lb injetors will gring everything back into harmony.
Thanks for posting the picture or I may never have seen that.
Ghost Pony
Ghost Pony
Bossier City
Maf
I'm going to install the 19lb injectors and try to source the correct maf sensor housing. (however, this thing ran great for a year like this and now its not so i'm unsure if this is the problem)
cleared out cm codes and ran KOEO codes again
81-85 (egr stuff) and 96 again (66 was gone)
ran koer codes
12 41 91 33
