Your parts seem a bit mis-matched without a simple tune. Especially considering the 351w.
Eric
Tuned by EFI Guy SN95 TM04 ECU tuned and chipped.
Tim
Eric
You replaced the heads? Did you first try something simple like resetting the base idle? If your idle is all over the place try resetting the base idle before going all over the board.
Did you get a spare ECU from EFI guy? If you did maybe check with him on swapping it out. Maybe a failing capacitor on the ECU starting to act up. I saw his video on repairing these boards hes's one smart feller.
I had to replace my IAC valve because mine was running at really high RPM's at idle. While I was troubleshooting, I also remember reading that the MAF sensor can cause what your describing. I actually changed my MAF sensor but it wasn't the issue so I brought it back to the guys at the parts shop. I've been buying quite a few parts from them so they didn't mind when I returned it. Have you tried a new MAF sensor yet?
How is the voltage? I did a motor in my sons 89 FSB it would run like crap if the voltage was low . It would crank strong so it didn't show signs of a low battery. I swapped parts for a day till I put a booster on the battery, fixed everything. Worth a check
If the ECT didn't fix it, then it probably means that it is having trouble once the computer tries to go into closed loop. It will be in open loop until it warms up to about 160 or 170.
If it runs well and then goes bad, then fuel pressure likely isn't the issue.
So, you have a chip installed for the tune? Have you checked to make sure it is still connected well?
x2 I've been encouraging a reset of the base idle twice and haven't heard if it was ever tried. All the changes made including changing heads would indicate the computer probably needs to relearn the base idle.Have you tried disconnecting power for 15 minutes to reset the computer? See if it runs well when warm after that. If it does, and then the problem eventually comes back, then there is more tuning to do because the adaptives are learning incorrectly.
Eric
Go here and do the steps below, "How to do it." Very simple.
http://www.muscularmustangs.com/idlereset.php
Are you running OBII. Get a code reader and check what temp computer is seeing and look at what the tps voltage and IAC feedback is. Also look at O2 sensor voltages and confirm the right sensor is wired to the correct bank.
Check all ports on manifold for a vacuum leak and check pcv valve.
Sent from my SM-G900V using Tapatalk
You solved your problem by unplugging the ECT. There is a spark and fuel adjustment based on engine temp (you probably knew this). When you get warmed up and enter those bin values it is not correct. You need to adjust your tune. Idle is very tricky / sensitive to tuning with EFI. For example all I did was swap a C4 to 4R70W and I needed to re-rune my spark and fuel at idle because ti would hunt (600 then to 700 then back to 600 in a slow rolling idle). A few clicks in my tune and it idles stock and I never even opened the hood. I just waited until it was warm and idling poorly then adjusted the trim on the bins or cells in the map right around there.
