EFI idle issue
bigmuddy
Marthasville Missouri
My rig just recently developed the problem of trying to die when starting from a cold cold start. After that it seems to run and idle just fine.
The IAB and other sensors are not new but don't have many miles on them. So I guess I need to take a look at the IAB anyway as well as the sensor in the coolant tubes to see if they are working properly. Haven't had time to run codes yet but thought I would throw it out here to see what the EFI gurus think?
Ben
Viperwolf1
electron whisperer
Mine was doing the same thing for a while. I cleaned the MAF and IAC and it went away.
bigmuddy
bigmuddy
thanks man for the information. I will give it a try and report back. I actually beleive it may be the K&N filter as its gotten quite dirty and I refuse to clean it. Going to swap it out for a different cloth style air filter.
Ben
raven mad
fayettville
dont mean to hijack the thread, but what is the best cemical to use to clean the MAF ??? can you use just plain carb cleaner or is their some special super secret cleaner to use ...... hahahaha
