EFI non roller 351w
RedEyedMex619
National City, CA
Well a few of us have asked our selves should we put a new er roller engine or update our engine. Since i had a nice working 351w with little hours in it i have opted it to keep the non roller engine, now i have a few questions and i will try to put pictures as i do the teir down this weekend. I'm going efi I have the Lightning gt40 upper and lower, 400. I did the O2 Buds. I have the Computer 2 of them, 24lb injector and the mass to go with them. I also have a harness that i need to work on, Just ordert the pump, and some other little goodies, Explorer t-body.
RedEyedMex619
RedEyedMex619
National City, CA
First question: I pulled the distribute from a roller efi 351w, do i need to do this: If you are installing this fuel injection system into a older flat tappet block, you need to make sure you change the distributor gear to a cast iron gear. This will prevent you from chewing up the cam. If you don’t change it, you will damage the cam and the distributor gear, not to mention the metal shavings that will be introduced to the engine. This Steel Gear that is commonly used in roller blocks can be replace with a cast iron gear. It is a .531, and can be purchased at www.summitracing.com If you are installing this into a latter model roller block, the steel gear will work just fine.
fungus
Kaneohe Bay, Oahu
YES! If your distributor is from a roller cam engine and has the steel gear on it, you'll need to swap that dist gear for a cast iron one since you are installing this into a flat tappet cammed engine. Roller cam = STEEL distributor gear; Flat tappet cam = CAST IRON distributor gear.
Just to drive it home I just bought an MSD TFI distr for my 5.8 roller build. The PO must've had it on a roller cam cause it had a cast gear on it that was wasted! Teeth were all ground to a sharp point. The cam must've looked the same on the engine he was running. I swapped my steel gear onto it and it'll go in w/ my roller cam.
broncnaz
only the last year or 2 of 5.8L engines actually came roller cams 95-96/97 and all pre 1995 and lightening engines all came with flat tappet cams so if your distributer is off a lightening or pre 95 engine the gear should be correct. but if its a 95 or later distributer then yes it most likely is roller compatible and you'll have to swap the gear.
fungus
Kaneohe Bay, Oahu
I would NOT use this as gospel without confirming! My engine came from a '94 F-150 flareside and is a full roller cam motor from the factory. I keep hearing of similar instances like mine... If it's an F4TE block it very well may have a factory roller cam in it. Steel gear on distributor, "spider" and dog bones in the lifter valley, roller lifters & roller cam.
broncnaz
quite correct nothing is 100% gospel. best bet is to always verify and if in doubt just get the correct part.
RedEyedMex619
RedEyedMex619
National City, CA
Thanks fungus and broncaz.. Just food for thought so, there are non-roller Efi 351w put out by ford. that i can pull the distribute from. I know i pulled that distribute a few months ago out of an late 80's early 90's bronco, that had EFI. Hope i got lucky and when i get home that is what is sitting in my tool shed.
Once again thanks for the info.
mattt
Late 80's, Early 90's distributor SHOULD have a cast gear which would be correct for a flat tappet cam. You can visually see the difference between a roller and non roller gear.
I don't know if the roller cam gear is forged or billet machined or what, but it is generally smooth on non gear surfaces.
The non roller cam gear is cast and has a rough casting exterior on non gear mesh surfaces.
broncnaz
Most likely you have the correct one anything pre 94 will be correct. as was said the non machined surfaces of the gear should look like cast iron. where the roller gears are usually all machined.
RedEyedMex619
RedEyedMex619
National City, CA
Day 1
Well to keep all you guys in the loop I have started the demo of the old and in with the EFI. Took down the gas tank need new feeder hoses. Once i was there I connected the auxiliary tank to my existing fuel line in order to have it dump in to my new old 23 gallon tank i bought. Still need to run the fuel lines to and from the engine.
I took off the Carb and intake along with all the other thing holding it down, Put my O2 censers and did alot of cleaning. I finally put in the Lower gt40 intake. Have a few questions, are what do you use the back two water jacket traded holes for and there is a traded hole on the right side of the intake look like an mixture temp censor?
hear are some pictures of day 1..
Still need fuel lines and more censers..
hmh800
Depending on if you run EGR, and how you plumb it, you can use the pass side hole at the back of the intake for the coolant line to the egr plate. I plugged the other one. The threaded hole at the front driver (in passage to #5 cylinder) is for ACT sensor.
RedEyedMex619
RedEyedMex619
National City, CA
Day 3
Today i went to the bone yard to pick up a few things one was the fuel rail and fuel lines. Got the rails off an f350 90's with the 351w. "look out for that bolt under the upper intake". I did do a few things to the bronco my goal is to start her up by Thursday will see.
I put the fuel lines and injectors along with the fuel line harness. Also took header off, soon to be on ebay. to place the CPU there. Also placed the ACT and temp, oil.
Tomorrow work on that fuel line system.
HOw do i cover the hole for the egr in my lower..
RedEyedMex619
RedEyedMex619
National City, CA
Long story short, after stopping on the EFI 351w. My Brother dragged me back into it, (like brothers only know how). Well the update is that she turned on.
I had a hell of a time with the throttle Cable and the gas accumulator. B.C Bronco did me wrong on both items. Parts are on now on but they both had a 2-3 week lead time.
I ended up selling the Upper GT40 From the lightning will see if my budget build payed off.
Things to go do before the next trip around the block..
-Move the hi pressure pump. (tips)
-Finish the electrical use the new fuse box
-Connect gauges.
-* New Radiator Alum.
-* Move Battery
Then move on tho the cosmetic for a bit..
