Ford EFI and non-roller 302
mcknight77
Caldwell, ID
How feasible/doable is it to convert a non-roller carbureted 302 to EFI using Mustang 5.0 EFI?
I have a conversion kit and computer that I was going to use to convert my 1988 Mustang 5.0 to Mass-air. I'm thinking that with the addition of intake, flow meter, distributor, etc. that it should work fine on my 302. Am I missing something here?
bmc69
It's done often. No issues. Sounds like you have the list of what you need pretty much figured out.
dclack
The biggest issue in the engine firing order vs the injector firing order.
Scoop
Bronco Old Fart
Cuchara, CO
If the 302 is basically stock just run a speed density set up and the firing order will match. You only need MAF if you build the motor out of the SD computer range. SD works great and is cheaper to buy the parts. I'm running an 87 Cougar XR7 SD set up on a stock 74 motor with the stock v-belt set up. Works very well.
Ourobos
Big Island Hawaii
Sequential vs. batch firing (SD vs. Mass Air) might seem to run OK.. But the O2s are adding / pulling fuel from the wrong banks if you mix and match. Batch-EFI setups are usually the single HEGO type....one O2 reading both banks at the "Y" exhaust junction. Mass air was designed with two banks, and two O2 sensors on the Mustangs. I'd advise against it if you want the truck to run the way it's engineered to, and most efficiently. But it'll run 'OK'.
http://oldfuelinjection.com/?p=92
Scoop
Bronco Old Fart
Cuchara, CO
My SD set up is not batch fire. It has O2 sensors on both banks. My understanding is that batch fire systems came mainly on the F series and FSBs prior to 96.
Viperwolf1
electron whisperer
All speed density systems are not batch-fire. The '85-'88 mustangs were sequential speed density. No problem changing it to mass air. Ford even had a conversion kit for it. Either way it should run perfectly fine.
Sporto
I agree with Scoop. The SD setup is the way to go on stock or slightly modified 302 engines. I have setup from an 86 Mustang HO on mine with an Edelbrock Performer cam. I ran this engine as is with the Edelbrock carb and manifold for years, and when I put the EFI on it made a huge difference in the engine's performance and reliability. I know that the firing order that the computer is setup for is the HO one, and it is different than mine, but if this engine is just running "ok" then I would hate to see what running "good" would be. :eek:
Ourobos
Big Island Hawaii
You'd be amazed at what a properly running engine would reveal. I've had them running 'great', and via a tune gained over 30hp. It's normally the idle that's effected with the injectors not matching the firing order. Whatever floats your boat though.
M
mcknight77
Caldwell, ID
My 302 is basically stock, 8.5 compression, small cam, E-brock Performer and 500 cfm E-brock carb. Dyno'ed at 230 hp and 290 tq. Just looking for drivability. Sounds like the SD is the way to go, but I already have the computer an wiring for MA.
One last question: fuel pump?
Thanks for the help.
Viperwolf1
electron whisperer
Mass air is fine as is speed density. Use what you have.
You'll need a high pressure fuel pump at a minimum. Mount it as close to the tank as you can and it'll be fine. You'll also need a return line between the fuel rails and the tank.
M
mcknight77
Caldwell, ID
EFI Photo
Here's a photo of what I bought.
jw0747
San Antonio, TX
Looks like you'll need an EEC module (computer) and a wiring harness plus some sensors unless you didn't picture everything you got.
M
mcknight77
Caldwell, ID
I already have the computer. It's a A9L.
I'll have to source the sensors. And an EFI distributor.
I'm checking on a harness. I have a Mass Air conversion harness, but I'm leaning toward an aftermarket harness specifically for 5.0 into an early Bronco.
Viperwolf1
electron whisperer
Looks like a Mustang lower intake. Upper appears to be off something else. Might have a small sized throttle body. It should work though.
Scoop
Bronco Old Fart
Cuchara, CO
Also don't see the mass air flow meter and you'll need O2 sensors and bungs to install them. But you want to get new O2 sensors anyway! Looks like a couple of sensors are still attached to the lower along with all the injectors and the fuel rail. Good score!
