You will want the sub-harness that connects to the harness in your picture and plugs into the O2 sensors and also the section of the main engine harness that has all the injector connections along with the ECT, ACT, TPS sensors.
I don't think you will need the chassis harness that has the fuse box on it, but remember that the chassis connectors (grey/black/brown and green) won't have the same wire colors as listed on the
www.fordfuelinjection.com web site. You will want a wiring diagram for the vehicle you got that from. I tried to convert a 91 Mustang harness to match Ryan's design. I traced every wire back to the ECM and then tried to make a cross reference to the colors listed on the
www.fordfuelinjection.com diagrams. I then labeled every wire with masking tape. It was very tedious and the diagram for the specific vehicle would have made life much easier. On the other hand, I really understood what was what when I put it back together.
If I was going to do it again, I probably wouldn't try and convert it to Ryan's design. I'd keep it all intact and just make the appropriate connects to your Bronco harness, ground , 12v, run, and start.
The temp and oil pressure wires on the harness in your picture are easy to splice into your Bronco guages. The wire colors should even match. Then you just need to find the run, start wires for your Bronco harness.
BTW after trying it several ways, it runs much better with the EGR, CANP, and AIR sensors hooked up instead of trying to eliminate or trick the sensors with diodes.
