dirtdrdave
- Joined
- Mar 28, 2008
- Messages
- 61
Hi All,
I think I have a fuel pressure problem. I have an original 302 with mustang efi using an RJM harness. Recently it was off the road for an extended period while body work was completed. At that time, I also installled a painless wiring harness. It was running well but only for a few weeks. One day, it began sputting and stalling producing no power. I towed it home, now it won't start. It sounds like it is about to fire, but doesn't. I do have spark. Interestingly, my fuel pressure gauge was registering zero when it did run. I assumed it was bad. I changed the gauge and now it still registers zero when I am cranking it and fuel pump running. I have a bc broncos tank with the fuel pump inside. I can hear the fuel pump running. I changed the fuel filter, that did not help. I removed the vacuum hose on the fuel pressure regulator. There is no gas coming out of the top. When I remove the fuel pressure regulator or the fuel pressure gauge I do get fuel leaking out.
Could the fuel pressure regulator be causing this issue?
I can hear the fuel pump running and do get some fuel as I mentioned when the pressure gauge is removed. Is it possible that the fuel pump is delivering fuel, but just not at a substantial pressure?
Thanks for reading! Any help is appreciated!
