stretch
Installed a GM unit in tank, seems to work well. Going from external pump. What I’ve noticed with this new pump, once the engine is turned off, the pressure will drop from mid 40 psi to 20almost immediately. Over the coarse of the next hour, it will drop to zero. No problem with restarting the engine or anything. I just remember my external pump would hold 20 or so psi for hours or more. I’ve checked for leaking fittings on the fuel line, nothing found. Should I be checking into this further, or could this just be a function of the new pump?
