Probably because there likely isn't one. There are probably master cylinders out there that do bias, and those that don't.From what I've read almost all MCs are 50/50 with proportioning done outside the MC. But I've never found a definitive answer to that matter.
I'm using the Wilwood prop valve set at maximum reduction. It says it's able to reduce the rears by 72%, the most on the market.What brand adjustable bias valve do you have? It should be able to dial down that press so the rears don't lock.
There is more to it than brake bias tho.
Gotta ask about suspension and the rear unloading too. If the front is diving and the rear is unloading you could have very little weight on the rear axle during a full emergency stop.
Like Tim mentioned, on two different types of brake bias valves I could dial the pressure down so the rear wouldn't lock up unless I was on gravel.
I used to run a 1.33" dia MC and now Tim and I are both running a Chev 1.25", Micro lock, Chebby JD6 frt & rear, no rear premature bias
I didn't think of the front pads glazing. I'll have to take it apart and look. I don't *think* I did anything to glaze them. New pads, rotors and new (not rebuilt) calipers. If anything I might have glazed the rear pads, on the first drive I realized I had the line lock closed on the rears (less than 1/2 mile).Interesting on the pad vrs caliper.
72% reduction (bias valve) on the rear with a 56%/44% bias to start off with and it still doesn't stop rear lockup at slow speed w/o locking the front makes me think the front pads possibly were glazed when braking in. That's pretty common but with your research/skills I'm thinking that you already looked into that? If the front never locks due to the pads being glazed that could point 100% of the problem to the rear when it might not be the entire cause of the issue? Just a thought. I did a lot of brakes and did a couple brake schools but that was eons ago. EONS
Did the engineers suggest pad changes as a fine tune if the Eldo's/Wilwood can't do it all on their own?
I think you are on the right track with the reduction in bias using the Eldo calipers. There is a lot to a complete brake system design- I really enjoy the number crunching.
There are 2 "Eldo" calipers.I replaced my El Dorado calipers with 89-97 chevy S10 4x4 front calipers. They fit in the brackets I originally got from BC broncos. I’m not sure of the piston or pad size, I wasn’t able to find that #. If you aren’t using the parking brake, that might be an option.
Kyle
I didn't either until recently.I didn’t know there were 2 types.
170 was after arriving home after normal driving for 10+ minutes after heavy braking/bedding. Some highway miles and a few mellow intown stop signs and pulling into my shop.How hot are front rotors / wheels with normal driving? If they’re 170, that seems way too hot, likely driven by your draggy brakes.
Are these floating calipers?
When you pry the caliper back like you're removing the caliper off the rotor, how quickly does the cup try to extend and push the pad back against where the rotor was? Does it move on it's own and create the same amount of drag (when put back over the rotor as before or does the cup sit there till you hit the brake pedal then the drag on the rotor is created again?
Discs always drag, but not so much to create extremely hot rotors. I learned that back in HS as I burnt my fingerwhen I was checking the brg caps and thought the rotor looked/smelled hot. Ouch! lol These were the rotors on my girlfriends (wife now), MGB. I had no idea they had that much drag. Long term memory = I experienced/lived the event ha
Interesting, you mean the issue was the flat part of the backing plate or the “ears” or “tangs”. Hard to imagine the flat part that the piston pushes on would be an issue.The front pads were hanging up and not retracting. I followed advice I got on a FB post to check the sliding surfaces on the brake pad backing plates. It wasn't obvious but when I took a file to the ends of the backing plates it showed that they weren't cut cleanly. I filed off just a bit until the "burrs" were removed. The added clearance made a huge difference. The hubs spin much freely than before. The truck rolls easier as well. After a similar drive the rotors only read 110*. I'm expecting my mileage will improve as well. I had noticed a significant drop in fuel mileage since my axle swap.
The rear bias still remains so I'll be swapping in the Eldo calipers sometime soon. I'll be putting some miles on the truck before them just to make sure of how it's performing.
Sent from my Pixel 7 using Tapatalk
Yes, these are 1996 F350 brakes (very similar to the next gen Super Duty brakes). The ends of the brake pads ride on a stainless shim on the caliper hanger. I took just a bit off the ends of the pads where they ride on the shim/caliper hanger.Interesting, you mean the issue was the flat part of the backing plate or the “ears” or “tangs”. Hard to imagine the flat part that the piston pushes on would be an issue.
