electrial ?
buckedup
Ft myers, Fl
Need some help..when I turn my headlites on, my parking lites in the front go off...but the turn signals will still work..put the light switch to the park position and they come back on???:-[ What do I check??Everything works great except that. Thanks, Mark
broncnaz
more than likely you need a new headlight switch should fix your problem
Skuzzlebutt
PhD, Dr. of Broncology
Honeymoon Bay
They're supposed to be that way. Later years had the parking lights stay on. They prolly changed that the same year the safetynazis mandated the oversized parking light lenses.
kwspony
Roseville
I don't think they are supposed to be that way. My 68 had the same problem until I swapped in the 351. I had everything out of the engine compartment, cleaned it and painted it. When I put everything back the problem was solved. I think you have a bad ground somewhere. remove the wiring, clean up all the connections and try it out.
stevew
Elliston Montana
Ditto , they go off when the headlights go on , on the earliest Bronco's , specifically '66-'68 , maybe early '69's .
flint_knapper
BRONCO GOD
Harvest, AL
the earlier vehicles have the lights wired
that way. they where called Parking Lights.
I don't know what year they changed to
running lights.
buckedup
buckedup
Ft myers, Fl
Well thanks for the help..I fell alot better now... chased those damn wires all night(not really). Glad they are made that way.. my 74 doesn't do that so I was worried. Thanks again:D
kwspony
Roseville
NOw that I think about it, when I swapped in the 351 I re-wired my alarm and jumped the front and rear parking lights together on the headlight switck so they blinked when the alarm went off. Easy to do, just a 2" wire and 2 male spade connectors and that's it.
You might even be able to re-orient one wire on the switch's plug to make it work. GM used the same switch for cars in the early sixties that they did for later cars, but wired differently. I just moved one wire to another plug on my '65 and, voila. Lights all the time.
Is your switch out by any chance? I can tell you how a '76 is wired since I have a loom and switch right here on my desk. We can compare and maybe you can swap a wire if it's worth the trouble to you.
