electrial problem with old gauges;bronco dead
lsukevinc
Holly Springs
When I bought my bronco in October, the previous owner had 3 aftermarket gauges installed under the radio (temp, oil pressure, and ammeter). The ammeter never worker but the temp and oil pressure did. I wanted to get all of the gauges working in the original cluster to work, so I have been working on each slowly one by one in order for all of them to work. This week, temp and oil pressure now officially work in the original cluster.
Last night I disconnected the ammeter and all hell broke loose. The previous owner had a wire coming from battery side of the solenoid to the positive side of the ammeter (picture 1). Then, a wire from the negative side of the gauge went back through the fire wall and tied into the voltage regulator/alternator wiring (picture 2). I am assuming this was how the original ammeter was wired? Once I disconnected the old ammeter, the bronco is dead….no lights, no horn, no power to the fuses, nothing. My battery is good ( I even hooked up my booster pack) and I do have 12 v to the battery side of the solenoid, but nowhere else. I tried to connect the wires back exactly as they came off and nothing, still dead.
My question is what to do with the wire going back to the voltage regulator/alternator wiring (picture 2)? Does it need to be grounded or hooked up 12 volts? The wire coming off the battery side of the solenoid I assume can go away since I am disconnecting this ammeter? Please help. I do have a good multi meter and a wiring diagram and understand the bronco wiring for the most part.
70_Steve
Old Guy
The wire that goes through the ammeter is part of a loop that supplies power to the entire Bronco. That loop starts at the BAT+ side of the starter solenoid as a fusible link, continues on as a Black wire (38), into the passenger compartment and changes to a black w/Yellow stripe wire (37) at the ammeter. Wire 37 is then spliced into a couple times to supply power to things like the ignition switch and headlight switch. Then 37 comes back out into the engine compartment and ends ultimately at the alternator output. By disconnecting the connector at the ammeter you disconnected all the power to the Bronco.
I can't tell enough from the pics to know what wire you're referring to. But, here is a link to a set of schematics that should let you know.
seabiscuit68.tripod.com
L
lsukevinc
Holly Springs
I tried hooking the wires together you see at the back of the old ammeter and nothing. the wire coming off of the battery side of the solenoid did have 12 volts at the old ammeter. I don't understand why it is dead if I re connected the wires back together.
savage
Bronco Nut
Renton
The Ammeter is positive on both sides, not negative on one side. are you sure its a ammeter or is it a volt gauge, by the picture it looks like a ammeter.Here is how the ammeter hooks up. You said you hook it back up and nothing, are you getting 12 volts on the other side of the amp gauge?
That's a nice bit of instructions you posted savage, but it's not the same for a Ford ammeter of the day. All the safety protocols are likely the same, but ours are a feed-through inductive loop with no hard connections at all on the back of the gauge.
The only connection is a bullet-type push connector to mate up the two halves of the wire feeding through the loop. It's an install item, since the loop is continuous, but it's only putting the two wire halves together and is not attached to the gauge in any way.
As to why your truck no longer has power Kevin, you might have fried the fusible link right there at the starter relay. That first section of Black wire is fused but you can verify it by testing.
The only other reasons I can think of would be if there is either a fault with the connector that you just pushed together, or some other break in the wire.
Sorry guys. Just looked at the pics more closely and realized that the gauge in the pic is that type. But as I think someone asked already, is that also an ammeter, or just a voltage gauge?
And that is quite the mess-o-wires you got there hoss! You might be best served by replacing a lot of that with your own, cleaner and more traceable wiring to start fresh. Your current lack of power could even be from some kind of fuse the PO installed somewhere.
hard to say at this point.
Good luck though!
savage
Bronco Nut
Renton
That's ok Paul, I had to take a double look, at the pictures. After looking at it, looks to be a amp gauge by the 10 gauge wire on both sides, a picture of the front of the gauge would determine if it is a amp gauge, if it is He should be able to hook the two end to gather, and it should complete the flow. That's why I ask if he checked the other side for 12 volts.
L
lsukevinc
Holly Springs
Good luck though!
Paul, the old gauge was an ammeter. It did have a bolted connection on both sides, but never worked since I bought the bronco. I think I can figure this out. I am decent at wiring. I agree I should re wire the area near the alternator/voltage regulator. I am running a HEI dizzy, so a lot of that wiring can be trashed. Don't we all love previous owners?
L
lsukevinc
Holly Springs
I figured it out last night and everything is back to normal. The previous owner made a big loop to wire up the aftermarket ammeter. What had me confused was both post on the ammeter were showing 12 volts but once the return wire tied into the area near the voltage regulator, no voltage was left. I guess the wire was bad and finally shorted out when I moved things around. It worked fine for years before I attempted to clean thing up. Thanks for all who responded.
