Idle/electrial issues
OldBarnBronco
I'm having a strange (to me) issue with my 77. It starts and runs fine for the most part. However, when I turn on the lights or hit the brakes the idle drops maybe 100-150 rpm. I also notice I lose a few inches of vacuum when I do the same and the needle flutters as well a bit. This morning when I checked things again and turned on the lights and adjusted the dimer on the headlight switch the tach goes dead, oil pressure and temp peg out and the amp meter does not read. I readjusted the dimmer so I do have the oil and temp back though. Crap I hate electric issues. Can anyone at least point me in a direction here? Thanks much!
bteutsch
Run a ground to the instrument cluster. You can use the same bolt that connects the ivr. Possibly replace the headlight switch if ground doesn't fix it. I don't know how the headlights or brake lights would affect the idle but anything is possible. I had issues with my gauges especially the temp gauge would read high after turning on my headlights and grounding the instrument cluster fixed it. I ran a ground wire from the bolt that holds the ivr down on the cluster to one of the brackets that holds the bottom of the dash where it bolts through the body. Also make sure you ground the body to the frame, the firewall to the motor, and the motor to the frame. I used dorman ground straps from the auto parts store for the big grounds, and a piece of 12 gauge wire for the cluster ground.
Steve83
How exactly is the tach wired in? What wiring harness is in the truck? What do you mean by "does not read"? The ammeter always shows SOMETHING, even if it's 0. Click these and read their captions:
I highly recommend doing the voltmeter swap shown in that last one.
