Electric Fuel Pump on Carb Engine.
TexasBronco
Waterford, MI
My mechanical fuel pump on my 351C broke a seal and filled the oil pan with gasoline. I am looking to just put a cover plate over the hole and run an electric fuel pump. Any idea what type I should lean towards? Mounting locations? Do I need a return line? Pressure regualtor? Any junk yard finds able to do the job?
The carb is an edelbrock 650cfm 4 barrel with a few mods doen to increase offroad ability.
blubuckaroo
Grease Monkey
Ridgefield WA
Why don't you just replace the mechanical? They are more reliable, safer, and a stock one won't over pressure the needle valve. Also, it's really hard to find an appropriate mounting location that's below the bottom of the tank.
dbruce9035
Hutto, TX
if you run a 5-7 psi pump you do not need a return line. i would think that would be all you need. i would mount it close to the gas tank and put a filter before it.
broncnaz
The Carter P 4070 is a excellant pump I've been running one for close to 30 years on my bronco and only changed it because it was 25 years old I carry my old one as a spare now. Mines mounted on the drivers side of the frame just forward of the rear axle with a filter between the pump and tank. no return lines needed.
While mechanical pumps are fine I really think they dont make them as good as they used to as they seem to go bad a lot quicker than they used to and the good named ones cost more than the carter electric pump. Use the cheap ones and your changing them every couple of years and end up spending more than the electric. of course maybe its just the additives in the gas nowadays thats causing the problems.
Socal Tom
San Diego, CA
The carter is a very good pump for that setup. Ford used them in the 460 motorhome applications back in the 80s before EFI, so they will have plenty of flow.
Mount it as close as possible ( less than 3 feet of hose) to the tank ( assume that a filter is worth 1 foot of hose). That way you also have some protection from vapor lock.
Tom
grant_71
Could always go with an in-tank pump off a 88 Bronco, low pressure, slight mods to make it work, clean install though.
Grant
JWMcCrary
X5 for the carter. I welded a plate to the outside of the frame and bolted it there to get it farther away from the heat.
