Electric fuel valve
lewain
Newbie
I am thinking about replacing my manual fuel valve with an electric fuel valve.
My question is, that looking at the PDF installation sheet on Wild Horse's it appears to me that when connected, the dash mounted selector switch will draw from the opposite tank than the way the selector switch is marked.
Does that make sense? Am I looking at the drawing wrong?
khmt
Newbie
No experience with WH’s system, but if you are looking at converting to EFI as well, Holley has a dual tank solution.
Don't know the instructions. But if that is the case, swap some hoses around will fix it.
armynavy17
I haven't looked at the directions you reference in a few months, but the new electric valves are "fail to main". So if the switch fails or the wiring to the valve fails it will default to the main tank. Does that help?
lewain
lewain
Newbie
I just want to replace my old mechanical valve under the drivers seat with the Wild Horses electric tank selector valve. No electric pumps, sticking with the mechanical fuel pump on the engine.
