The guy at the auto parts store gave me the idea to take of the positive cable with the negative still attached to the battery to see if the alternator was indeed working correctly. When I did so, a wire under the dash started burning and kicked off a ton of smoke. However, I could not find that specific wire.
Attached are some pics of some of the crazy wiring I have going on. The red wire in pic one goes through the firewall and is jammed in between the fuses in the glove compartment. The black wire and white wire in Pic 3 are from the back of an aftermarket 3-gauge set (temp,volt and oil pressure) and are connected to nothing. I am guessing at least one should be grounded.
Can I run the red wire into the positive battery cable? Any ideas on what might have started smoking?
