Electrical Issues. ( hot wires)
Broncofan1
76' 302. When its running all is good but if it quits running with the key turned to the run position the R-GN wire (in the dash ) from the ignition switch to the ignition coil gets so hot it begins to smoke. Any ideas of possible causes?
76Bronco302
Sherman, Tx
Must have something wired incorrectly. I recently had an issue with some wiring and realized I had a connector going to the wrong terminal. Simple fix just check a schematic and make sure things are going where they need to be.
B
Broncofan1
Nothing has been rewired is the weird thing and everything is wired correctly according to the schematic.
Bitch'nBronco
Loose Cannon
Ringwood, NJ
Check the wires to see if they're chaffed on anything, could be contacting something causing it to heat up. If not that then maybe try adding in a relay to the coil
Turn the key off.
That's a resistor wire and is designed to get so hot the factory even covered it in a heat resistant jacket and kept it separate from all the other wires.
Of course, it was also a different color up in the harness in most cases, so not sure about yours.
How long with the key on does it take to get hot enough to smoke?
Is it run separate from the other bundles of wires and is it long enough that it's folded over itself a couple of times?
Is it covered at all?
Is it Green w/red the entire way, or were you just saying that about the ends that you could see?
Have you changed any ignition components elsewhere?
Can you feel the ignition module getting hot under the hood? If so you may be having a meltdown that's overworking the wire.
Good luck.
But definitely keep the key off. You're never supposed to leave the key in RUN for longer than it takes to start the engine or do a quick diagnosis of something.
Sorry if you knew that already, but it's come up a couple of times this month already, so I thought I'd mention it.
Might be more possibilities to work out here. But for now let us know some more details.
