First off, electrical issues and me are similar to gasoline and a match.
Started up the Bronco and pulled it out of the garage earlier. I drained and refilled my radiator and then put on a new air filter. Went to start it back up and nothing. It still has power for my lights work and the brake warning light comes on (I assume this means I have power). When I try to turn it over it just 'clicks' now. It's a factory 302 with a carb and the factory wiring harness.
I checked all my connections and hit them with a wire brush and still nothing. For what it's worth, I did jump a car the other day with a cheap set of jumper cables and fried the cables before I could even get them unhooked. Not sure if that matters or not. However, the Bronco ran fine the rest of the day and I've started it several times with no problems after that prior to this.
My starter had been acting up a little I suppose, but nothing to signal that it was on the verge of death at any moment.
After class tomorrow I was planning on picking up a new starter solenoid and a starter if I can find one in stock.
What else should I be looking for or checking?
Thanks in advance.
Thanks in advance.
