My electrical system just stopped charging. There is a new alternator that I bench tested. It is hot. Not the problem. New battery. tested and okay. there is continuity between the alternator fuse and the key on wire that turns the alternator on. That wire is good. If it's not the alternator's ground, then does anybody have any ideas? The volts were 13.5 to 14 without charge when the alternator was working last week. It would drop to 12 under load. But now, it is 12 dropping below 10. New centech harness seems to be okay. I know this post might seem like a complete waste of time, but IF anybody has any notions, It would help and I'd try to chase it down. Thanks.
