Electrically Stumped
PocketKings
Nashville
So, I joined the Bronco owner's club a few weeks ago. Love it, love working on it, etc. It's a '73 and a beauty.
There's just one thing.
It's been having electrical 'issues' that have me stumped. I got it and it ran fine, then suddenly wouldn't start. I alternated between having power to other places and not (lights, radio, etc.). I checked the likely culprits - fuses (replaced), battery, battery cables (replaced), starter solenoid (replaced).
One day, it started and ran OK for 2 weeks. I believed the issue was the neutral safety switch and some blown fuses, because the combination of messing with both got it running. However, gauges were acting funny/sporadic, turn signal would work occasionally, etc. I figured I'd have time to check it all out when I got back from vacation to look for another culprit.
Came back from vacation after we'd had a ton of rain and had no power. I charged the battery and got it going fine again. Next day, nothing. No power at all. Charged battery full and still no power. Checked battery for dropped cell and it's fine and fully charged (I was hoping).
So I'm back to the diagnosis phase. I stripped off all of the electrical tape on the main wiring harness to check wiring. Fusible links look good, but while checking I found a burned up wire that I can't seem to identify off of the available diagrams.
Off my alternator are three wires - Black/Yellow, Orange, and Black/Red. The Black/Red is fried in multiple places from the pigtail connector to where it connects to the bolt that holds the voltage regulator in place. So, this leaves me to think it's a ground? It needs replacing, regardless. Black/Yellow and Orange go through firewall to parts unknown.
Here's the crazy part. I disconnect the pigtail in preparation to replace the Black/Red wire and now it starts like a charm. I have full power to everything I've checked, but don't want to run it too long with the pigtail undone.
I'm obviously going to replace that wire, as it's the only one that's bad (and it's very bad). I am curious why the truck starts now and what, exactly, that wire is. Most importantly - could this be the cause to some/all of my issues?
bmc69
If I was going to hazard a gues, it sounds like you ahve a very bad or even missing ground and that the alt ground wire tried to take up the slack.
Make sure you have rock solid grounding between the body and the engine and the battery negative. The actual negative battery cable takes care of the bat to engine part, but the other is very important and oft neglected.
70_Steve
Old Guy
Bookmark this link! http://seabiscuit68.tripod.com/
Here are a bunch of color-coded (Thanks seabiscuit68!!) schematics for various year Broncos. Yes, that black w/Red is a ground. I ran for years without that wire, but I make sure I have an excellent grounding scheme in my Bronco.
My guess is you have a bad alternator. But... That's just a guess...
Edit: Just read bmc69's comments, and thought I'd expand a little on the grounding scheme. The negative battery cable should be bolted directly to the engine block. There's a tab on the block, behind the alternator, that's a convenient place to attach the cable. From the engine, attach grounds to both the body and the frame. I use braided grounding straps from the HELP section of the auto parts stores. You can also find them in the battery cable section. I installed one from the rear of the intake manifold to the firewall for the body ground, and the other from the same bolt as the negative battery cable over to the passenger side frame rail.
I won't say it's a good idea to run without that black/Red ground wire. Replace it if you want. But I ran for 2-3 years before I noticed it was missing, and my charging system worked fine. I chalked it up to " If it ain't broke, don't fix it."
73azbronco
On my 73, the electrical issues sounding like yours where hacked away by the PO who bypassed the ignition switch. You may also want to diagnose if you have a hot wire after the ignition switch with the ignition in off. I also had numerous burned melted rubbed through wires in the area through the firewall and under alongside the frame by the aux tank. Also one wire rubbed through by the start solenoid which just rubbed through by sitting on the fenderwell for 30 years, you couldn't see it until you lifted the wire off the fender.
P
PocketKings
Nashville
73azbronco - I'm not discounting having to run all new wires. These aren't butchered, fortunately, but they are original and old. That's my concern - a worn wire 'somewhere.'
70_Steve - I have already replaced the battery ground, but haven't done anything from engine to body. That's happening tomorrow, for sure. I also have a small ground wire from the negative battery cable that needs to be attached to the fender.
Sucks that the ground to the alternator is not necessary. I was hoping for a breakthrough, not another red herring. Thanks for the color coded schematic.
My other big concern is related to the rain we got here (6 inches). The truck got wet inside. That's another factor to consider, and certainly won't help a rubbed through wire.
Thanks for the advice. Keep it coming if you think of anything.
70_Steve
Old Guy
While not exactly a breakthrough, bmc69's observation is important, in that it points out the possible and likely lack of a proper body ground. Apparently that alternator ground wire was trying to carry the load of a proper ground.
I'm still leaning towards a bad alternator. Possibly shorted diodes... Most auto shops can test the alternator.
If your alternator and/or engine block and any points where the alternator mounts have been either painted or are loose or covered in oils and gunky stuffs-unknown, that little ground wire becomes more important.
Regarding one other clue though, if you occasionally lose power to all the other accessories, then there are two points that commonly control that. One is the main fusible link on the Black w/red wire at the starter relay/solenoid, and the other is the bullet connector under the dash near the ammeter. If either one fails or comes loose then you lose power to everything.
The only other scenario that makes sense just now is that if somewhere else on those same wires, there is a fault or break or burned out section of wire.
The fusible link may be partially blown, but not fully. That could explain the intermittent issue with power to everything else.
And if the connector under the dash is loose or really rusty, it can do the same thing.
Good luck.
P
PocketKings
Nashville
Here's my update -
The truck was starting when I began my work. Still no rear lights (back-up, tail) or running lights. That's probably another issue.
I replaced the burned wire (ground). I added another ground from the block to the frame. I also added a ground from the negative battery cable to the fender. All throughout I checked the truck and it started.
I began to diagnose why I have no back lights, saw several exposed wires and fixed them and checked the ground. Went to start it to check lights and the truck had no power, again.
I have power to the fuse box and all good fuses. The fusible link looks good and the wires back look good. The only bullet connector I can find look like its for the aftermarket radio. I don't want to hack up the fusible link if it's not necessary, because I'm already doing more patches than I'd like.
After poking around and cursing it out, I went back in and it started up. Still no back lights or running lights, but everything else is working.
I'm considering all new wiring, given the dramas I'm having. Every time I poke around there's another worn wire or bad patch. Open to thoughts.
70_Steve
Old Guy
When you say "the truck had no power"... to what, exactly.
The reason for asking is that different things on the Bronco get power at different places (sort of..). There is a loop of wire that supplies power to everything in the Bronco. It starts pretty much at the battery, or more specifically, at the fuseable link (which is connected to the +BAT side of the starter solenoid). It leaves the fuseable link, goes inside the truck, through the ammeter, then back out to the alternator as that black w/yellow wire.
That loop is spliced into in several places, to provide power to several different things. Headlights, cigar lighter and emergency flashers are all powered off that loop. The headlights are powered with unfused power (although there is a circuit breaker inside the headlight switch). The cigar lighter and emergency flashers have their own fuse.
The ignition switch is also powered off that loop. Besides supplying power to the starter solenoid in Start, and the ignition in Run, it also powers the accessories in Run and Acc.
So, when you "have no power" see if any of the things listed do have power, starting with the headlights. Even with the key Off, your headlights should light. If not, theres only so many places you could have a problem. That circuit is from the positive battery cable to the +BAT connection on the starter solenoid. Then through the fuseable link to a black w/red wire #38. Wire 38 goes inside to the ammeter where those connectors are at the ammeter. From there it turns in to a black w/yellow wire #206 and goes to a splice where it powers the headlights.
You can break this down into very simple specific circuits. As long as you are making quality repairs to your harness there's no need to consider replacement. BTW, my take on a quality repair does not include anything that crimps. Soldered joints with heatshrink tubing are the only way to go.
P
PocketKings
Nashville
When it has no power it is 100% dead. No headlights, no anything.
When headlights work, then the truck starts.
When it does get power, I still lack some functions - some gauges, and all tail lights, plus running lights. Turn signals and flashers work. Heater, wipers, etc. all work.
It's either dead or partially working. I've traced that main loop and there are no visible issues. Much of it is taped together with the main wiring, and I haven't pulled it out of the dash and stripped it clean yet. Fusible link looks good, but if I have to change it I will.
All repairs have been soldered with shrink covering, but I ain't the best at soldering.
70_Steve
Old Guy
Should be pretty simple to trace down then. If all else fails, try the wiggle test. When the truck has power, turn on the headlights, then start wiggling all the wires, starting at the fusable link and up to the firewall, then duck under the dash and continue wiggling. You should find a spot where the headlights flicker.
If you have a meter you may want to check the battery voltage when the truck is without power. Dunno about Nashville, but here in Phoenix, it's very common for a battery to develop an intermittant internal connection. You could turn on the headlights OK, but then try to start the car, and the extra current draw from the starter causes the connection to open inside the battery. Load tests are the most common battery test here.
