Engine assembly advice
screamin reel
Calgary, Alberta, Ca
Bought a donor 351W from an 89 F250. Rebuild with 32,000 miles.
I have taken it apart to clean and paint which is done.
Did NOT remove crank, cam, pistons etc as compression and oil press. all checked out good.
Cleaned up heads as well.
Does not appear that the front or rear main seals have leaked.
I have purchased a Felpro gasket and seal set so everything is here for the whole engine.
Should I shoot a little fogging oil in cylinders, timing chain and other areas as it will be stored in a garage for another few months ? Valve springs ?
I have read about RTV and such for the intake, water ports and oil pan. Anywhere else ? I have been told that I should not add anything to a paper gasket. Is this correct ?
Should I fill it with engine oil once buttoned up ?
Any advice is appreciated.
Bucky
New Bern, NC
I've heard not to fill it with Oil until your ready to run it. Mine was stored for a couple years with no oil, just the assembly lube and it seems do be doing well!
Everything else I think your right on!
Dirtyboy
Cape Cod, Mass
Long sorry but accurate........Head gaskets apply dry! That is the only gasket that should not have anything on it. After the heads are on you should have the intake bolts cleaned and ready to install use silicone/RTV(I use BLACK RTV) on the intake mounting surface of the head and either end of the block in between the heads. Only put enough down so that the RTV is transparent, it should not be that thick, you only need it to hold and partially help seal the intake manifold gaskets. Apply gaskets as printed on gaskets and make sure they are secure. Next, where the corners of the intake meet the block (1 in picture) put a 3/8" to 1/2" blob of RTV in each of the four corners. DO NOT allow to harden(in the picture I do not have the gaskets on, but this is what I mean by transparently apply RTV. But blobs of RTV should be here when gaskets applied). Next put same transparent amount of RTV around the water jacket holes on already applied intake manifold gasket. Apply end seals on block in between heads(very important-most people just apply 1/4" of RTV here, but when you start having blowby the silicone just blows out and "presto" you have a leak, gaskets are made for a reason). And apply intake manifold, setting it directly straight down, no left to right schimmy! Apply bolts in holes and attempt to hand tighten, Then with a 1/2" 3/8" drive ratchet start tightening the bolts from the center of the intake out to each side, in an 'x' pattern. Roughly as tight as your weakest hand can go. Start from center again and check tightness, usually you can get a little more. Use the transparent technique with the oil pan gasket mounting to the block, and globs at each corner where the paper gasket meets the rubber end seals. Apply transparent coat of RTV to top of gasket and apply oil pan. Insert all bolts by hand and tighten from center out-WATCH FOR GASKET SQUISHING OUT FROM PAN AND BLOCK!! you have to watch for the gasket compressing as you tighten. With the oil pan on do apply oil to srings and rocker arms and let naturally drain down into pan, but do not apply the recommended 5-6 quarts. You will only be wasting it. Apply valve cover gaskets as normal and install valve covers. Just what I do to all mine and at work. Good luck. Sorry spare used motor in garage.
Dave in Houston
Baytown
Just my 2 cents but if the engine is out I'd think about replacing the rear main seal before installing the engine. It's easy to do while the engine is out....but you will have to pull the engine to do it later, unless it's a two piece, and even then its not easy. Cheap insurance.
It wouldn't hurt to pull a main bearing cap or two and inspect and plastigage just for grins...same on rod caps.
Marvel Mystery oil is great stuff for spraying in old engine cylinders for protection....just not too much of it.
Good idea to re-torque all the rod and main bearing caps while you have the engine on a stand too.
Good luck.
