samamarshall
- Nov 3, 2008
- 244
I have my 2000 mountaineer 5.0 short block ready to be reassembled. Never been this far into an engine, so It's been quite a learning experience.
I have a few questions before I put everything back together:
I was planning on using High temp silicone on the timing cover and oil pan. The copper stuff. Anyone suggest something different? I was planning on cleaning the mating surfaces real good, and do a small bead on each side of the gasket. For the oil pan I'll put that extra amount on each side of the curved portions at the front and back. Same thing with the water pump.
I have a new oil pump and shaft, anything about installing that other than bolting it in a torquing it? There is a ring on toward one end of the shaft, does this go toward the pump or into the block?
Okay last question...for now ;D I was planning on covering the lifters in assembly grease and inserting back into the holes they came out of, install the holddowns, etc., then install and torque the heads, than put in the push rods and rockers to button up the valvetrain. That's the correct order right?
I appreciate the help guys. While this engine will end up sitting on the stand for quite some time, its exciting to get it put back together, and motivation to get the bodywork/paint started and finished.
