I have same size motor, carb, gears, tires, and lift as you. I stated off with the 670cfm truck avenger and it was way too big. I went to the 470 and it ran better, but still not perfect. So, I went with smaller jets (from 57 to 50) and it runs way better than it ever has. It is still on the rich side and I plan on putting smaller jets until it finally leans out. Now it has good low end throttle response, and has more power in the top end too. I used to have to shift before I hit 4000 rpms because the power dropped off, now it wants to rev out.
Could be other things too, but if you have a 670 on there I'd look at the carb first. Also, the early 670's bogged and holley will fix it for free. They fixed mine, but it was still just to big of a carb for a 302.
