Engine bogs down
pcreape
Upstate NY
I have a stock 302 with a 4 bbl Holly 600CFM mounted on a stock 2 bbl manifold w/ an adapter plate. When I press down on the accelerator it bogs down for a sec then kicks in. Also bogs down when accelerating. Do I need a 4 bbl manifold?
If you would like the 4 barrel carb to work properly you should have a 4 barrel intake.
But that may not be all of the problem. but I wouldn't bother trying to tune it until that was done.
Itsa67
It will definitely be more efficient on a four barrel manifold. It sounds like it could be an accelerater pump problem though if its bogging when you first crack the throttle.
P
pcreape
Upstate NY
would the accelorator pump make it back fire as well...not bad just an occasional pop. I know she is timed out and everything...
Itsa67
I think it could cause the backfire. If it has backfired and its an older holley then sometimes they blow out the powervalve and you have to replace it (not an expensive part). Your best bet is to get one of the holley tuning books that they sell at the autoparts stores since they aren't to expensive and have tons of knowledge. I haven't worked on mine in a long time so I don't remember alot of the specifics. Hopefully someone that works on carbs more often chimes in and gives you some more valuable info. You might want to post up what model of Holley you have to as it can make a difference. I hope your not running a double pumper or that would explain your bog right there (you definitely need vacumm secondaries for your application).
P
pcreape
Upstate NY
It has had one good backfire since I put it on about six months ago. Its 4160c with vaccum secondary. I had just put it on week before I had the brainstorm to redo the wiring harness. When I got the wiring harness all done I realized I wanted a new ignition system. So I threw in a MSD ignition system and it wouldnt start so I thought it needed some starter fuid...nope. it needed a new ignition contro module. So with a new box she started up for sure...with a two foot flame. Ran good for a week or so then it started to give me problems...cleaned out the the tanks and still nothing to speak of.
Itsa67
On the older carbs one good backfire could blow out the power valve and cause it to start running crappy. Some of the newer ones have better power valves that don't get hurt but I am not sure about what yours has. It's not all that expensive of a part and I'm sure you could upgrade yours if need be. Hopefully someone will know if yours has blowout protection or not.
oleguy74
calif city ca
the 4160 you gave should have blow out protection for the powervalve.power valves are the same.4160's and newer holley's have a little check valve to prevent blow out of p0wer valve.that dont mean power valve isnt bad.if power valve blows out it would flood out.does it go ok when you ease into throtle?also with engine off look in carb open throtle and see if accelerator pump shoots a good stream of gas.
P
pcreape
Upstate NY
I think I have bigger issuesnow than just carb issues.I pulled all my plugs to make sure the rings weren't leaking. All looked good until I got to 7 and 8 and both were dripping in oil.
oleguy74
calif city ca
that sounds like accelerrtor pump.at least put plugs in it,and check pump and try it again.oil on plugs can't be good.if it prety much stock,put the medium spring in vac.diaphram on secondaries.ther is five colored springs.white is ligtest black heaviest.get a kit from summit raceing.
backpain
when I would ease on it, would be fine. Just when I got it is when it bog right down.
600cfm on a stockish 302 at WOT can easily run too rich. Depends how you have it tuned, but that Holley has potential to be dumping more fuel than your engine can use. I don't know first hand whether or not that carb can be tuned down enough for your setup. Someone may chime in. Are you running a stock early 302 cam?
This does not of course address your oily plug issue. Could have some worn out valve guides. Could be many other things as well. How many miles on your heads?
BG's 68 Bronco
sounds like accelerator pump issue. It may need a bigger squirt initially when starting out and accelerating.
P
pcreape
Upstate NY
I appreciate it. I will find out tomorrow if it works out I willpost it in here, I appreciate the help..
broncnaz
You might want to check the squirter size that you currently have probably has 28 stamped on it. A step up to a size 31 can cure the bog. Along the same lines if the squirter is to big say a 35 it can also cause a bog. But I have a feeling the oily plugs are contributing to your bog. Summit or jegs carries the squirters so if your ordering a kit you might want to order a squirter also.
