Engine dying
stretch
Montgomery, TX
Well, I finally sold the heep and bought a real vehicle. I purchased a 77 sport with fuel injected 302. The problem I'm having is that the engine acts like it's vapor locking and dies when it gets hot. I have a push pump and a high pressure pump so I don't think it is vapor locked. The PO said something about a RFI module in the distibutor and needing to move it to a remote location? This is my first go around with trouble shooting FI. Any ideas? Oh, it does start right up after the engine cools.
Buckshot
BC, Canada
make sure the fuel lines aren't getting to close to the the exaughst manifolds, thats the only thing i can think of that would cause it to vapour lock once warmed up
The modules are good or bad. Either work or don’t. There is the possible sort of bad one, but for the most part they will work and then just shut off like you turned the key. Usually not going to start again until they are replaced.
If it acts like vapor lock, then it probably is. Injected motors do vapor lock. If you can put a fuel pressure gauge on it. A test one is OK, just route it out the hood (cowl vents work great) and watch it as you drive. When it acts up watch the fuel pressure. 35~45 PSI while running is what you want to see (varies depending on throttle input/load). If it starts going under about 25 while it is acting up, you have a fuel problem. Pumps, routing, who know. Hard to tell how the previous owner did the conversion. There is not standard way.
If the module is acting up, the tach will tell you. The needle will drop all the way to 0 even with the engine still turning over (coasting with no power). Not to be confused with a stalled engine that isn’t turning over while the vehicle is still in motion. The module is the signal generator that tells the tach how fast the engine is spinning.
