Help needed - engine keeps dying
SeaBiscuit68
Tacoma Wa
I can usually figure these things out myself but this one has got me stumped. My engine dies at what seems to be the exact moment the thermostat opens up. I can start it back up and have no more problems for the rest of the day. It started this about a week ago as the weather has gotten colder. Since I've been working two jobs, I haven't had a chance to check anything out. I've got a little bit of time this morning to look things over but don't know where to begin so I'm looking for some input from the board.
Some details:
My truck has never liked to drive off without warming up for a few minutes.
I wasn't able to reproduce the symptoms by warming it up to operating temperature in the driveway. Apparantly it will only do it while driving.
I don't remember which thermostat I'm running, either 185 or 195.
302, manual choke on a Holly TA, headers, rv cam.
Any ideas will be greatly appreciated.
Thanks,
Mike
HotWheels
Twilight Zone
I wonder if that might be caused by the lack of holley truck avenger mod? missed you for breakfast....well i missed breakfast too.
SeaBiscuit68
SeaBiscuit68
Tacoma Wa
Well yesterday was an adventure. I started the day trying to reproduce the problem but couldn't. I then decided to head across town to work on it at my friend's shop. About half way there it stalled and for the rest of the way I could only get about a half city block at a time, running and stalling. Finally a couple of blocks short of his house it just wouldn't start anymore. I decided to replace the fuel filters and took a walk to the auto parts store to get them. I didn't know if it was the filters being replaced or it cooling down during that time but it started and I made it to my friend's house. It was idling fine and I couldn't find anything wrong so I headed home. Halfway home it stalled again. Couldn't get it started. Battery acted drained. I yanked the battery and charged it overnight. This morning I'm going to try to get it back to my friend's house since it's closer to there.
Some things I noticed.
During my first adventure heading across town, once I noticed the fuel pump didn't shut off with the key (it's electric).
Once after stalling I opened the hood and the see-thru filter was nearly empty. I turned the key on and saw it fill up.
Anyway, wish me luck today.
HotWheels
Twilight Zone
could it be a short in the battery? that would affect those items in the way you desribed. what does the electric fuel pump derive it's power from? I had a cherokee that did this to me. .02
..and you know i dont know anything....
:p
next sunday good for you?
U
Unregistered
Guest
sounds like electrical problems to me. I'd first check your fuel pump wires (clean ground, good positive connection etc) if you say your fuel pump is acting strange and there was no fuel in the filter.
SeaBiscuit68
SeaBiscuit68
Tacoma Wa
I began my troubleshooting with the idea that the fuel pump wasn't getting enough juice and that's what made it fail. So I check the output of the alternator and saw it wasn't doing it's job. I found that the plug for the 1G wasn't plugging in well. Who knows how long I'd been driving around on just the battery. Anyway, the sensor wire that the alternator was using showed a 2 volt drop across it's length so I bypassed it for now. All seems well again. Whew! Except now I'm only firing on 7 cylinders. I musta fooboo'd something. I came in to eat lunch and then go see what I did wrong.
I figured out why it was doing it when the thermostat opened up. I had my electric fan set to come on at that same moment, and there wasn't enough electricity to go around.
(HW: Sunday is fine.)
