Engine keeps dying...you tell me...
MartyG
Well, I've been dealing with this for around two months now
My next-door neighbor's buddy has been a Ford mechanic for years so he's been helping me on this.
I have a 351 inside my EB, and it started cutting out like it wasn't getting gas. I noticed a lot of crap inside my in-line fuel filter, and knew that my main tank was full of crap.
I replaced the main tank which was indeed absolutely full of crap, installed a new fuel pump, new ignition wires, coil and distributor (MSD system).
My buddy also completely rebuilt my Holly four barrel, which he said was only functioning on two and also had crap in it.
Now the engine is absolutely purring like a kitten, when it's running... but after 4 miles of driving, the same problem comes up out of nowhere. I'll be driving and suddenly it starts choking like it's not getting gas if I put it in neutral, it will idle but sometimes it will die as well. When it does, I immediately popped the hood and check the fuel filter and I find it full. Initially after I started it up, it runs great; the problem seems to get worse the longer I drive it.
So here is where I am:
My buddy/mechanic pal tells me we should replace all the fuel lines because there might be a leak or clog. Also possibly the main tank/reserve tank switch. He also mentioned it might be that the eccentric for the fuel pump is worn out... so I picked up a new one to replace it with.
So what do you guys think? Can the fuel filter be full and the carb still not get gas?
I'm kind of stumped and I miss driving my Bronco!
70_Steve
Old Guy
You seem convinced that it's a fuel problem. Have you absolutely verified that?
When it dies, besides checking the fuel in the filter, check to see if there is fuel in the carb. Remove the air cleaner, look down inside the carb and actuate the throttle. You should see gas squirting down inside the primary venturies. If yes, the carb has gas in it. If no, then there's a problem getting gas into the carb.
A quick check to determine lack of fuel is a squirt of starting fluid.
Is your tank vented to atmosphere?
Justafordguy
X2 on the fuel tank vent. Maybe try to open the fuel cap halfway the next time it tries to cut out.
x2. When mine would do that, it was the needle-and-seat sticking. Although it happened occasionally with my 2100, my Holley 600 would absolutely do it every few days. By the time I got rid of it, it was getting pretty beat up from me hitting the area around the float bowl with various implements of destruction.
Each time it would do it, I'd slap the carb with the handle of a screwdriver or something, and I'd immediately hear a nice whooosh sound and the fuel filter would empty like it was under pressure. Which it was.
Do what Steve said and verify that fuel is, or is not, squirting out of the nozzles.
MartyG
MartyG
Hmmm...ok, will give it a try. Maybe it's plugged.
markperry
Try taking the fuel switch valve off and blow some air through it too clean it out! Also replace all fuel filters, and check the fuel lines that are rubber, they tend too calapse when they get old! Hose clamps can be an issue also!
MartyG
MartyG
Well, same problem; runs perfect and then problem happens after 4-5 miles. Tried the gas caps when it died...no luck.
I pulled the filter off..ran the fuel line into a bottle and got plenty of pressure...when idleing though.
I'm going to bypass the fuel pump & try an electric pump on Saturday. I'll blow the lines out as well.
Frustrating.
patterdale
Sounds like it could also be a plugged exhaust problem. I have seen this twice in my lifetime. Once in an old truck my dad had and once in my own. Trucks would start and go a while but enventually loose stuff in muffler would pile up and plug it up. They would both idle fine but when it happened you even thought about opening the throttle and they died. Just a thought before you spend a lot of money on carbs & parts. Also saw it once on a turbo mustang in the 80's The converter disintegrated and hatched the turbo. That car couldn't help itself to the shop for repairs.
MartyG
MartyG
It has new exhaust. Haven't checked spark...thats next.
bluebronco69
Damascas, OR
you replaced alot of things at once, sometimes thats a bad idea.
maybe try switching back to the stock ignition.
maybe the MSD box is heating up and shutting down, thermally or some kinda circuit breaker inside...
same with the coil. check that too, or replace with the one you were using.
process of elimination.
since there was one problem and you replaced 5 things, we have to verify that all 5 things are working right before we know if any of them even addressed or fixed the problem.
jw0747
San Antonio, TX
would bet it's something wrong with your ignition components most likely your MSD box (if you have one) or your distributor. if there's a local speed shop near you that sells MSD components, most likely they can test your stuff or you can call MSD's customer service # on their web site. from personal experience MSD has really good customer service and a willingness to make stuff right.
MartyG
MartyG
Hey guys, thanks. I think I'll check out the msd box.
73azbronco
same old mech fuel pump? Try your idea of an elec pump. any way to verify bubbles in line from cut/broken plastic line?
Other than that, yeah, dropping in five things means you need to go back and try the old parts again one at a time or different parts one at a time.
I bet fuel pump/clogged line after pump.
carmi
Oroville
Still sounds like a fuel delivery issue. Check your fuel pressure with a timing vaccum guage. It should be atleast 4lbs, preferably 5 or 6 lbs. Are you sure there aren't any more fuel filters.....maybe the oldstyle that is part of the mechanical fuelpump? What about vent lines into the gas tank? If the vent lines were clogged it could cause a system vaccum that might override the suction ability of the fuel pump.
remi1566
bronco dying....
I have had carbs rebuilt on broncos several times before they functioned properly espically after it sat for quit a few years and I flushed the main tank...you sure your friend replaced everything ..espically the float? It could be that some particulars were still in the line and made its way in the carb again..it doesn't take much...Just a thought...
new to bronco
Milton Fl
Remove the gas cap and drive it around see if it run longer, i know it sound craszey but friend got a 75 that would run one day not the next maybe stop four or five times in 5 miles, everthing was new, removed cap ran great drilled small hole in cap still run has never stop.also had jeep do same thing .
MartyG
MartyG
Found the problem.....it was the MSD box! Hit it with a screwdriver...engine died.
Did it a few more times...no more problem. Obviously it has/had a short in it and I'll eventually have to replace the box, but now it's running perfect, no more problem.
Man...that was driving me nuts.
Thanks guys for all the input!
