Engine Hesitation - Troubleshooting
Izzy
Texas
I'm finally wrapping up the install of a new 5.0 engine (for the 3rd time in two years). Got everything running and only need to get to the exhaust shop and finish installing the pitman arm but noticed a small issue last night.
The engine runs great at idle but when I go to give it gas, it hesitates before reving up. Where should I start to troubleshoot this? I'm pretty sure it is timed right but would that be the first clue that it is not?
Appreciate the tips.
EFI Guy
TheEFIguy@gmail
BFE
Verify timing with a light.
Verify correct fuel pressure.
Check for vac leaks.
Pull codes.
In that order.
Is the motor stock with stock electronics?
Izzy
Izzy
Texas
It is a mostly stock 5.0 from a 98 explorer with the RJM harness and Mustang EFI components.
Fuel pressure is 40, not codes except the normal ones. I will verify timing and check for leaks.
