Engine removal/re-install tips
Banjer Picker
I’m pulling my engine soon to do some maintenance, clean up and replace motor mounts and clutch. Just checking to see if the CB family has any tips, tricks or recommendations for the process. For example should I losses the cross member?
Mainly I’m thinking about when I go to mate the motor and my NP435 trans back together...it seems like lining up the splines and getting the angles right could be a challenge.
Thanks!
Master Chief
I have a C-4 but find it best to leave the motor mounts off when removing or installing the engine because it is easier for me to separate or mate the engine and the transmission. I find that this also keeps the head away from the drivers side of the firewall.
B RON CO
Statesville, NC
Hi, the important thing is to use a clutch alignment tool, which often comes with the clutch, pressure plate, throw out bearing package. I would look at the pilot bushing. I would resurface the flywheel if it looks burned, but usually I just use a 3M scotchbrite cookie in the die grinder. I would put a little dab of grease on the pilot bearing, input shaft where the clutch rides, and on the throw out bearing clips and hole, and fork ball. I wouldn't touch the cross member. You will have to support the front of the tranny with a jack. During install level the engine and use the jack to adjust the level of the tranny. Eyeball it all straight, and push the engine home. You may have to turn the rear drive shaft a little if the input shaft does not go right through the clutch splines.Tighten the bolts evenly and gently until the engine bell housing are back together. Good luck
BronCowie
Old Timer
Vancouver, WA
^^^This^^^ (I have a C4 also)
My 1st attempt was with the mounts attached to the block.
2nd attempt was with them attached to the frame.
3rd and final attempt was leaving them off altogether and then installing them when engine and tranny were bolted up.
