Oil Pan Removal Without Pulling Engine??
tcb-1
Shawnee, KS
I know, silly newbie question. But I have the dreaded oil dipstick mount flange leak at the pan. Seems like a common place for drips....
I'd love to pull the pan and get it sealed up in a few weeks when I have it on a friend's lift.
Thanks gang!
bronconut73
Yup it will come off without pulling thethe engine but even if it didn't you would only have to lift tge engine slightly. The tranny could come right up with it but keep an eye on the fan/shroud/radiator.
There may be some slightly deeper pans than typical out there that could require this slight lifting of the engine.
There are some real deep pans out there that may require far more effort.
70_Steve
Old Guy
I know, silly newbie question. But I have the dreaded oil dipstick mount flange leak at the pan. Seems like a common place driops....
Thanks gang!
It comes out by just lowering the front differential and suspension relative to the oil pan. Either leave the wheels on it, raise the front a couple inches and put jackstands under the frame in front, to hold the front end up. Or let the front axle droop by removing the wheels, put jackstands under the frame and lower the front axle assy.
Use a one piece pan gasket for reassembly. Get a kit that has the pins to hold the gasket in place. I've done it without the pins by using the little zip-ties through a few of the bolt holes. Oh, and be sure to use silicon sealer on the corners of the pan, at the front and rear main caps.
tcb-1
tcb-1
Shawnee, KS
Thanks guys!
I did notice that some of the vendors carry a plastic type retainer that allows a person to put the pan in place while adjusting it.
I did a search, and there are several guys who fixed the leak at the oil dipstick flange. Anything from pvc, to removing it and sealing with a gasket, to actual seal welding. Is there a tried and true method that anyone can recommend? The welding method seems a bit more durable.....
Billsboat
Rowlett tx
Hi I need to do the same thing as you to my 71. I would be interested in u r progress, and any tricks u may discover on the way...pictures would be nice too. Good luck!
Broncitis
MEB Founder
I did it in the parking lot at the barracks when I was in the Navy years ago. Stock height Bronco, had to jack the front end up to get enough clearance with the front diff.
Would be pretty easy on a lift if you were supporting the frame and not the radius arms with the lift arms so the front suspension will droop.
73stallion
Eugene, OR
I've done it a few times. Stock Bronco needs to be jacked up about 2" to clear the track bar, or you can just drop the upper track bar bolt and let it drop down. It'll come right out.
KyleQ
Its really easy when you cut the engine cross member out - :D
trekgurl
squid when you say weld,, you mean mig right?
I have heard of some people using JBweld stuff but, mig welding would seem to fix the problem once and for all? Is that over kill? The other question is why this area wasn't made permanent in the first place? I'm thinking they expected this thing to eventually wear and one would need to fix it so they attached it like this?
I need to fix mine because when I had my headers installed they "wrung" the dipstick tube around and broke off the bracket where it would attach to the manifold. That got it started leaking where the tube goes in the oil pan. So much for custom work but live and learn.
Is there any need to replace the front and rear seals while the oil pan is off,,? not that I can tell it's leaking but should this be done?
I've add some misc pics I've collected off here,, not mine.
tcb-1
tcb-1
Shawnee, KS
Yep, I meant mig welding ;)
Billsboat,
Haven't had a chance to get on it yet. I will definitely post a step by step when I get there. When it's hovering around 100 in the garage, I limit my time out there!
Billsboat
Rowlett tx
Tcb-1, I hear ya on the garage temp. I'm in Texas and am dealing with the same issue. Fall can't come soon enough! I will keep an eye out for any up dates on your project.
