Engine struggles to turn off
laffycaffi
Seems backwards, I know. But my 302 doesn't turn OFF very well.
When I try to turn off the ignition, it dies as it should... almost. And then the engine kind of keeps going again. Not fully, almost like it's trying to keep going. I had to sit there for like 20 seconds today after I removed the keys, waiting for it to wind down.
I don't understand it. I also have noticed it's idling kind of high lately. Could it be related?
Thanks,
Mark
broncosam
Your engine's ignition timing is off, probably to far advanced. Is your engine stock ?
broncosam
If memory serves me well I believe stock ignition timing is around 12-14 degrees BTDC ( before top dead center ).
1970 Palmer
Also check the idle speed, too high will contribute to your "run on" issue. Some engines were equipped with an electric idle solenoid that closed the throttle plates further than the normal (700 to 800) idle speed to prevent dieseling. Make sure the choke fast idle cam is not hanging up, make sure the automatic choke is working properly. Today's poor ethanol gas contributes to the dieseling problem. Make sure your timing is set to 8 to 10 degrees BTDC, and not ATDC (which is retarded), causing more engine heat). Plug the "intake vacuum" line at the distributor when setting your initial timing.
John
Madgyver
Bronco Madman
turn it off with trans in gear. adjust timing. running hot causes dieseling or what is called, "run on"
All of the above are legitimate suggestions. But let’s check some things like, is this bronco new to you? Has been running fine before this and suddenly changed?
Your high idle is a definite giveaway. Your carburetor’s choke could be stuck a notch or two too high (choke closed) or some linkage has bound up from grit or gum.
Are you familiar with any of these items in your engine compartment at all? Or is this your first older vehicle?
We might have to see some pictures to see what you’re working with, and walk you through and talk you through some of the new things you’ll have to deal with.
In the meantime, if it’s an automatic transmission leave it in drive when you turn the key off. If it’s a manual then just start to let the clutch out and gear as you turn the key off. This will subdue the engine slightly.
It could be too much gas continuing to pour into the engine after you turn it off, or it could be the spark advance as the others were mentioning, or a combination of several things.
L
laffycaffi
Thanks. I’ve have this bronco for 14 years. I always work on it myself but this is the first issue I’ve had like this. Could be cheap gas for sure. Could be that the choke is getting stuck. Sometimes giving it a quick rev makes it settle.
This started out as a small hiccup now and then to happening much worse every time.
High idle will do it. When young I would crack the throttle just a little when shutting off one engine and it would run, rattle shake, and pretty much be a diesel engine for several seconds or until I lifted off the throttle.
If you haven’t done it in a while, you should at least take the air cleaner off and spray the throttle and choke mechanisms with carburetor cleaner. Then spray them again with something like WD-40 to temporarily lubricate and see if that helps.
WD actually stands for water displacement or dispersant, but as we all know it does act as a very good, even if temporary or short term, lubrication.
I don’t see if you mentioned what year your bronco is, but is it electronic ignition or still points? If it still points it more than likely needs adjustment and cleaning, if not a full replacement.
When was the last time it had a full tuneup?
1970 Palmer
I would doubt his run-on problem has anything to do with his ignition points or electronic ignition, as both are "turned off" when the key is turned to off. Initial timing is important only because it makes the engine run hot and ignite the low quality gas still flowing into the glowing hot carbon build up in the combustion chamber. Just like a diesel, it's actually running without any type of electronic ignition.
High idle speed, sticking linkage, are the main causes of this problem.
John
Slowleak
Georgia
If you have an idle solenoid make sure it is adjusted properly. It should allow the throttle plate to close completely when the key is switched off. Idle speed should be adjusted thru the solenoid idle speed screw.
Rustytruck
Ford resolved this problem with the idle control solenoid on the carburetor in the later model Broncos. my 1974 had it. turn the key and the solenoid pops up when you press the gas peddle. this sets the idle run speed when the choke controls come off. when the key turned off it cuts power to the solenoid and drops the idle down too low to diesel and engine quits.
My '71 had one, and I'm pretty sure I've seen them on '70 models. More vaguely, as far back as '69. I know they were in use before that at least on some vehicles, but don't remember seeing them on earlier model Broncos and frankly I did not look for them way back when. By the time I started really paying attention so many had been modified, tossed out as "just more smog crap" or lost in a carb swap.
Mine and some of the older ones were just a basic electric solenoid on a simple bracket. No dashpot and no fancy adjustable bracket like in the pic above. It was just a simple angle bracket with a hole and the solenoid was held in place (and adjusted) with a pair of thin nuts on it's threaded shank.
Worked great too, and I still have it. In a drawer unfortunately, because every time I changed carburetors, I thought it was too much trouble to try to adapt. Plus I was changing them around pretty often and didn't take the extra time to make it work each time.
But I also never had the same problem with any of them, so it was not a deal breaker at the time.
