Engine/ transfer angle mock up
nvrstuk
PNW
Like several have mentioned on this post already- the angle is not a "must have" measurement.
Much of the "correct angle" has everything to do with the proposed use of the rig. This looks like a street/mall crawler (as we call them) Bronco so driveline issues usually aren't an issue (unless you're going with a lot of (edit) lift- like 4-5").
Stock or up to 3 1/2" suspension lift & you are good to go with more than the "common-not hard fast rule" of appr 5deg or so. When you have too much angle on the ujoints when flexing or the frt axle is at full droop- that's when you could have a problem.
Slap a 15 dollar angle finder on it for curiosity & keep putting it together as it looks very nice.
Driving it at 6 or 7deg won't hurt a thing. Looking at the tcase and valve cover to firewall clearance in your pics & you look fine.
What does a WH HD mtr mount look like-like a stock mtr mount or the ones that are sold with rd poly bushings in them?
And is your suspension sitting level, at its final height? Or is it all brand new and not full weight of the vehicle on top?
Whether that matters much in your case or not, it’s still skews the measurements.
ntsqd
heratic car camper
Upper SoKA
I use a digital angle finder for stuff like this, and set it's zero on the portion of the frame that I expect to be sitting level when everything is settled.
Steve83
I need a angle finder tool...
I highly recommend a modern digital cube, and there's no reason to get one withOUT lasers. I have this one:
But with the coupon right now, this one is actually $5 less than I paid:
...I can aready tell I'm over the 5 degree recommended maximum angle.
Not really because the angle is RELATIVE to the chassis; not gravity/horizon/floor. To eyeball it, you'd first have to level the section of frame behind the radius arm bracket. But it's easier to just measure that part of the frame, and then compare all other angles to it. If the body mounts are good, the rear cargo floor is at the same angle.
(click this text)
I have the stock HD engine mounts from WH...
You should seriously consider returning them if possible, and going to fabricated poly mounts, which are vastly better. There are several suppliers, including me.
(click this text)
...measuting the gap between the x-member and trans mount and fabricating a polly spacer? Is this the best solution to leveling out the drive line?
I wouldn't. On Frank's '75 with '88 5.0L AOD, I modified the stock trans Xmbr to fit the Advance Adapter with the stock D20, bolted it all together resting on the engine mounts, and raised the Xmbr to get the engine angle right. Then I drilled new holes for the Xmbr brackets, and bolted them to the frame exactly where they needed to be.
(click this text)
(click this text)
(click this text)
