Engine Troubleshooting
brownflower
Ok so currently my bronco turns over and cranks up, it runs on a high idle; however, as soon as the idle drops the engine dies.
A little overview on my setup:
Mildly built 302 bored 60 over-engine is practically brand new just had it completely rebuilt, and aside from the break in, it has no miles on it.
I'm using a Duraspark II ignition every there is also new, as I have been trying to figure this out already and in the process I have replaced the ignition module, distributor, cap, rotor, coil, spark plugs, plug wires, as well as make a new harness for the whole thing. (Pretty much ruling out the ignition system at this point.)
I have a holley 600 4 barrel carb, I just got it back from national carburetor here in jacksonville florida they tuned down the jets and replaced the power valve.
I got the truck to run decently about a week ago.....was able to drive it up to the gas station and fill it up with gas for the first time (exciting!! lol) even during that time though it ran a little rough. The next day it started doing this whole issue of dying after the idle drops down.
Any help or thoughts on the matter would be greatly appreciated, it has me some perplexed at the moment i'm probably missing something obvious.
broncnaz
Id say either a vacuum leak or your idle mixture and idle speed is not set correctly.
What he said. Have you tried simply upping the main idle just a bit? Might be all it takes.
It could be something like your choke did not completely release from one of the high-idle steps on the cam before, but now that you've been running it a bit more, things are loosening up and you're bumping down to the lowest step and it's too low.
Seen it happen a bazillion times.
Things like carb adjustment, ignition timing inconsistencies, vacuum leaks, and other stuff, could easily do this.
Good luck. Hopefully it's easy. And not something silly like some rocker arm studs pulling out of the heads or the engine overheating.
DJs74
The description of running rough and stalling after fast idle falls off sounds like a vacuum leak to me also.
Check all your vacuum ports/lines around the carburetor, the vacuum tree behind the carburetor and check your carburetor bolts and make sure they are all snug. Also take a look at the carburetor base and make sure one of the four mounting ears aren't cracked. You can (carefully) use carburetor cleaner spray and hit things around various spots on the intake to check for vacuum leaks. If there is a leak vacuum leak somewhere on the intake / carburetor - the spray will be sucked in and the motor will momentarily speed up. This is not a "soak it" suggestion, just a "quick squirt" suggestion. **Watch your eyes and face** with the engine running, the fan will be moving air around and mist from the carburetor spray can catch that air and go swirling around too.
A less obvious and almost impossible place to find & diagnose a vacuum leak can sometimes be under the intake manifold itself. this can happen as a result of the torque / torque sequence used when the intake manifold was installed. Basically the vacuum leak is hidden and occuring at the cylinder head between ports/cylinders.
I would not suspect electrical but rather a vacuum or even possibly something in the carburetor itself.
Good luck
DJs74
Bferrari
Check your fuel filter, make sure your not pushing junk into your carb.
B
brownflower
Thanks for the ideas everyone, I have the day off so i'll be trying them out this afternoon. I'll be back later tonight with the results. :)
