Even more EFI questions.
PlaneDrvr99
Norman, Oklahoma
So I have read the FordFuelInjection.com and the 5 part article in Bronco Driver. I found these GT40 intake setup on ebay, what do you all with all the experience think ? http://www.ebay.com/itm/Ford-GT40-5-0-Mustang-Cobra-GT-Explorer-Upper-Lower-Intake-Manifold-/320783914525?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item4ab036161d
What throttle body would I mate with this? I have a 76 EB with the stock 302. My plan was to efi the stock motor. Going to use a A9P computer to run this beast. Also don't I have to change the cam in order to change the firing order? What cam would you guys reccomend?
Thanks for helping the "special one". Yes I am talking about me.
PlaneDrvr99
PlaneDrvr99
Norman, Oklahoma
Yes I wanted to run Mass Air. Should I get the Mass Air Sensor from the 89-93 mustang or the 96-01 explorer ? I plan on using the RJM Harness from BC Broncos.
Sorry I am new to the whole EFI conversion stuff...
What other Mods should I consider?
Duke Nukem
Simi Valley
Changing the cam is not necessary. It's true that the later 5.0 engines use a different firing order than the 302 (1-3-7-2-6-5-4-8 vs. 1-5-4-2-6-3-7-8), but with a mass air system you won't probably wouldn't know the difference. A few years back I did a mass air efi conversion on my 302 and it ran just fine with the original firing order.
The explorer intake like the one you are looking at uses a 65mm throttle body. Depending on where you are placing your air filter you will most likely want a standard mustang 5.0 style throttle body that that comes straight out instead of the explorer throttle body with the 90 degree bend. It should bolt up just the same, just find one that is also 65mm.
RustyShackelfor
Centerville, TN
i ran a motor in my 95 with the wrong order for about 2 years. it ran ok and all but it never was able to run quite right. got back to the right order and its just a lot smoother.
CJ who???
Banning, Ca...
Plenty of different options here. What I did was ditch the Explorer 90. My Explorer intake was off a 96 Explorer and I bought an EGR spacer plate from RJM (it has the correct throttle cable bracket holes to use the stang throttle cable). Bolt the Explorer TB to the EGR spacer plate and directly to the upper. Get a junkyard stang TB and take the stang throttle cable butterfly hardware off it (I'm drawing a total blank on the actual name of it, but the hardware that the throttle cable attaches to the TB and moves the butterly) and weld it onto the Explorer TB. With my 96 Explorer TB, I was able to easily install the stang TPS on it, also able to just turn the brass PCV inlet 180 to match the stang TB. I've read that some of the later model Explorer TB's don't have the brass PCV on them, just a boss for it. Once you get a JY stang TB and match them up, you'll clearly see what I'm talking about.
I wanted to use all stang sensors to keep it simple with the harness.
I also threaded the EGR hole in lower manifold and plugged it there (some peeps keep it and there is value in keeping it in tact).
Short story long is, I used a 93 Cougar shortblock, 96 Explorer heads and intake, 96 Explorer TB, 91 stang TPS, 91 stang ACT (threaded into lower mani), 91stang ECT threaded in correct boss in stang heater tubes, 91 stang mass air sensor, 96 Explorer injectors, 91 stang Bar air sensor and an RJM harness set -up for the stang sensors.
I'm kinda rushing through stuff cause I gotta go to work right now, but feel free to hit me up with more ??? and I'll get back with ya when I can !!!
Find build threads with what you have in mind and read them over and over. That's what I did. There's some serious talent and knowledge on this subject here !!!
ilovemaui
Pacific Moist West
It's pretty much mix and match. I used the '93 GT40 upper and lower with 1/2" spacer, GT40 heads, mustang TB and sensors, with explorer serp. That upper and lower looks pretty rough. I would look around a little more.
