Yes... More EFI questions.
WSM29
Engine is now in the bronco and I am finished with all the odds and ends. Headers, starter, front dress minus the radiator and shroud, and started running the harness. I have some wiring questions. I dont think I would... But for some reason I need to ask if I retain the factory brain box? If not I just seal off the old wiring pigtails? Also, do i retain the old stock voltage regulator and whatever that little jem is there on the side of the fender? Also, I have a new 1 wire 3G. The RJM harness that I bought used "never installed" from a fellow CB member has a different hook up. Do I need to get the BC broncos 1 wire adapter to plug in or is there a way to rig this up?? Anyone care to post of a pic of how they did their heat lines? mainly concerned about the valve. Which one plugs into which when using the mustang coolant rails? Also, I am retaining the factory water pump. I thought someone had named a part number for a hose on an early post that fit the water pump to mustang inlet tube? Any advice on this one?
To Viper- I know you mentioned earlier I needed to plug the EGR. I guess my noob on the EFI is really showing some colors as I cant see where to do this at. I am planning on just bolting the mustang TB right to the GT40 upper. I dont see any EGR plates to block? Pics maybe?
Thanks again everyone!! Shes close!
73azbronco
please!! put some blue painters tape over the intake holes, Please!!!
