Sorry you had to go through that guys. But if either of you have any pics of the bolts in question, or more details of the exact reason the one bolt/pulley is not compatible, we'd like to see/hear them.
Are the threads different? Does it put the pulley out of alignment with the belt? What exactly does it do that won't let it work properly?
If you have some, send any info, pics or suggestions to
sales@wildhorses4x4.com (attn: PaulB if you like) and we'll add the notes. Or, if it's a simple change to our bracket that can be made to take that into account, that would be an even better result.
I would hazard a guess that the reason we don't mention it is the prototyping was done on Explorer brackets we had in the shop, which happened to have the smooth rounded pulley. Then, the testing models (at least two different customers) were evidently just by chance done on the same style. So no red flags went up during that initial development process. At least not that I heard about.
Sorry too, that when you called, nobody was aware of the two distinct styles and how to get you quickly through your frustration. We (including myself) thought an Explorer drive system was an Explorer drive system and that was it. I've seen the two styles of pullies obviously, but that in itself never even jumped out as unusual, or as something to look in to.
Even when looking up replacements, they only ask you if you have smooth or ribbed. No question of what year, or whether open or with edge flanges.
I wonder if they were used on the bottom of the passenger side, and sometimes get swapped around? Seems like I've seen both down there too though.
Now I'm going to have to dig up the two systems I've got squirreled away to see what they have. I've also got one with the plastic cooling fan, while the other has a steel one. But didn't look for any other variations at the time.
Anyway, I know you've already spent a lot of time with your respective hair-pulling, but if you don't mind a little extra time, by all means please send us what info you have when you get a chance.
Thanks.
