Yesterday I completed installing the explorer serpentine belt front dress on my '67 with the original 289. Thank you to everyone here for the great technical write-ups especially the tech archive (http://classicbroncos.com/tech/explorer-5-0-serpentine-accessory-drive-belt-conversion). One thing that I never found was a complete list of parts, costs, and sources. I thought it might help others if I posted my parts list.
The entire thing went in without issue and it really makes a big difference in the underhood noise level. Now I no longer feel like the accessories are waiting to fail.
If I had one key piece of advice... if you are buying a "complete" explorer front dress from someone be sure you get pictures and a list of included parts. The "complete" setup that I purchased from a member on here turned out to be far from complete. It was missing the discontinued water pump pulley and power steering reservoir, the upper idler pulley, the tensioner, and the timing chain cover was damaged... but it was "complete"... live and learn.
Here is the parts list that I used:
Support Bracket Power Steering & A/C Compressor Ford# F87Z3C511CA Discontinued - Salvage yard only
Support Bracket Alternator Ford# F67Z10A313AA Discontinued - Salvage yard only
A/C Compressor Ford# 4R3Z-19703-A DENSO 4718125 $113 http://www.rockauto.com/en/moreinfo.php?pk=993270&cc=1362462&jsn=8
A/C Compressor Hose Block Vintage Air 045017 $49 https://www.summitracing.com/parts/VTA-045017
Power Steering Pump Ford# F77Z-3A674-DBRM A-1 CARDONE 20277 $30 https://www.rockauto.com/en/moreinfo.php?pk=29871&cc=1354564&jsn=10680
Power Steering Pulley Ford# F77Z 3A733A Dorman 300-009 $15 https://www.rockauto.com/en/moreinfo.php?pk=869978&cc=1354564&jsn=10686
Power Steering Pump Reservoir Ford# F67Z3A697AA N/A $15 Discontinued - Salvage yard only
P/S hose Explorer to 4x4x2 box BC Bronco 48-31410 $79 https://bcbroncos.com/shop/steering...e-hose-stainless-steel-for-early-ford-bronco/
Alternator Ford# 4G7Z10346AARM2 DB Electrical AFD0045 $87 https://www.amazon.com/DB-Electrica...ywords=Alternator&refinements=p_85:2470955011
Alternator Pigtail Wells 224 $9 https://www.amazon.com/WELLS-VEHICL...ywords=Alternator&refinements=p_85:2470955011
Serpentine Belt Ford# F77Z-8620-A GATES K060935 $18 http://www.rockauto.com/en/moreinfo.php?pk=4312&cc=1354564&jsn=10956
AC Comp Clutch Wire Dorman 85152 $8 https://www.amazon.com/gp/product/B000C5CCNG/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Lower Pulley 3 for Hole Balancer BC Bronco $79 https://bcbroncos.com/shop/engine/e...tine-crank-pulley-for-351w-early-ford-bronco/
11 Blade Fan Ford# F87Z-8600-FA MOTORCRAFT YA228 $56 http://www.rockauto.com/en/moreinfo.php?pk=379464&cc=1354564&jsn=4850
Fan Clutch Ford#F67Z8A616NA HAYDEN 2841 $89 http://www.rockauto.com/en/moreinfo.php?pk=1793624&cc=1354564&jsn=5275
Fan Shroud Wild Horses 5001 $185 https://www.wildhorses4x4.com/product/Full_Circle_Aluminum_Radiator_Shroud/Bronco_Aluminum_Radiators
Thermastat Housing Outlet Ford# FOZZ-8592-B FOUR SEASONS 84884 $8 http://www.rockauto.com/en/moreinfo.php?pk=819234&cc=1354564&jsn=7250&jsn=7250
Radiator Lower Crossover Hose BC Bronco $77 https://bcbroncos.com/shop/cooling/...-stock-conversion-pipelower-for-early-bronco/
Water Pump Ford# F87Z-8501-CA Flowkooler 1666 $95 https://www.wildhorses4x4.com/product/FlowKooler-Water-Pump-Explorer-5/EXPLORER5ENGINEPARTS
Water Pump Pulley Ford# F87Z8509AA $50 Discontinued - Salvage yard only
Upper Idler Pulley Ford# 6L2Z-6C348-A GATES 38001 $14 https://www.amazon.com/Gates-38001-...F8&qid=1521572009&sr=1-1&keywords=GATES+38001
Serp Tentioner w/pulley Ford# F65Z-6B209-BA GATES 38161 $32 https://www.amazon.com/Gates-38161-...F8&qid=1521569613&sr=1-1&keywords=GATES+38161
60mm lower idler Pulley (10mm smaller then stock, solves clearance issue) 2002 SAAB 9-5 GATES 36079 $23 http://www.rockauto.com/en/moreinfo.php?pk=1058013&cc=1388460&jsn=2143
Balancer 28oz w/ 3 timing marks Profession Products 80006 $70 http://professional-products.com/ha...y-small-block-ford-28-4-oz-in-harmonic-damper
Timing Chain Cover Ford# F67Z6019AA ATP 103039 $91 https://www.amazon.com/ATP-Automoti...TF8&qid=1521568808&sr=1-2&keywords=F67Z6019AA
Timing Pointer Ford# F1TZ6023A $29 https://lmr.com/item/LRS-6023B/must...NsAGEfDSuT3l1Ha8IsvDmUNT8CizFsp4aAnwAEALw_wcB
