Thanks for the responses!
My donor is a '96 Explorer. I grabbed the fuel pump out of it, but not the wiring for that. Should I just get a replacement for that fuel pump (don't want to put the used one back in, would rather have a new one installed). Aero suggested I buy a new one from Summit and they would make sure it fit my tank perfectly.
I am confused on the fuel gauge? Is it possible to use something to allow the Bronco gauge to work? I will be having my gauge cluster refurbished soon, so maybe I can work it from both the tank end and the cluster end?
I believe that the ohm readings are different from the stock Bronco vs. the Explorer... So I remember there was a thread where someone was tracking down a gauge that they could use in the bronco cluster that would work with the Explorer sending unit...
