- Nov 3, 2003
- 48,964
No, that's just a molded insulator. A fusible link is a piece of wire about 3" long.
Yes, they can be. And certainly any retrofit ones you buy at the parts store are going to be that way.
If not the connector itself though, then where is it on an EB? All the charge wire is of the same size along it's length (outer jacket size anyway), so a smaller section is not easily visible. And it's hard to believe that, even in their light-bulb's darkest hour, Ford would put an oft-burned fusible link down inside the taped portion of the harness with other wires. So visually at least, there is no obvious link spot after that molded "block" at the connector.
Is there a short section of wire that the manuf. somehow manages to make of a smaller gauge under the same size casing? If so, seems like an expensive way to make wire. Maybe the whole section, from the relay to the 3-wire connector farther up the line?
Since most of the meltdowns I've seen (not just Fords) have occured right there at the molded rubber piece, and finding the block all soft and half-melted seemed to be a good indication of a meltdown, and when fixing it was done by simply cutting off the end and renewing it with an add-on link (that short wire you were referring to), it seemed natural that this would be where the link was.
However, I'm sure I'm guilty of assuming that this was the case, since I've never pulled the wire apart, and assumed the smaller gauge wire was molded in right there at the connector.
And, just like in this case, I've certainly been guilty of assuming things before!
