Explorer Cruise Control
Datch
St Albert, Alberta
Hey guys, I am getting my wiring sorted out according to EFIGuys instructions, and was wondering if anyone has tried to incorporate the ford cruise control into their Bronco. I saved everything out of the Explorer except the steering wheel controls. I thought I would use an aftermarket control like the ones on eBay. I plan on using the 4R70W and will get EFIGuy to flash the computer. Will this be possible?
I've done it with an '80s vacuum cruise control. Never tried the Explorer non-vacuum version. Never found (nor even looked hard) for the wiring for an Explorer.
EFI Guy
TheEFIguy@gmail
BFE
Explorer cruise is very do-able. I've been planning a walkthrough on it for my next video. I don't know if those Mustang switches will work or not, it depends on their resistance values.
The method that I will be using is 2 SPDT momentary toggle switches with a couple of resistors. Going that route opens up a ton of different options for switches from period correct looking, to newer fancy stuff.
Steve83
There are 3 cruise systems used on the vast majority of Fords:
1) Vacuum servo, used until the early 90s (its primary sensor is on the speedo cable and produces 6 pulses per cable rev);
2) Electronic servo, used ~'90~04 (primary sensor is the ABS system's wheel or differential sensors @ 54 or 108 pulses per wheel rev);
3) Integral (inside the PCM), used from ~'04-now on vehicles with an electric throttle (drive-by-wire).
All Fords use the same resistance on the cruise buttons, regardless of the cruise system they control. So any Ford steering wheel will work with any cruise. And it's easy to build your own buttons and mount them anywhere you like to control any Ford cruise, just by mimicking the resistance of the factory buttons.
This diagram shows the resistances, and its caption contains the pinout for the electronic servo:
This is the Ford troubleshooting guide for the vacuum servo system:
All current Ford PCMs are built with cruise, but on vehicles without that option (de-contented), a steering wheel without buttons is installed, and the PCM is programmed to disable the system. To add cruise to those vehicles, the steering wheel is swapped for one with buttons, and the PCM is reprogrammed to enable cruise. Of course, this integral system can't be added to an older vehicle without swapping in the modern PCM, the engine with electric throttle, the modern transmission with shaft sensors, and much of the wiring harness.
If you're talking about using the electronic servo system, then there's nothing in the EEC to flash - the cruise system resides entirely within the servo, and does not rely on the EEC/PCM for anything.
I put the vacuum system on a '75 Bronco because I did an EFI swap to it, and the donor was an '88 F150 XLT, so I just used its cruise. It worked perfectly for over a decade, and probably still does for its new owner.
But the electronic & integral systems are significantly better in many ways. The most-apparent (and probably least-known) is that they respond to the buttons by exactly 1 MPH per button press (a feature exclusive to Ford cruise).
Most wiring diagrams for most vehicles can be found here:
http://www.revbase.com/BBBMotor/Wd
D
Datch
St Albert, Alberta
Any idea when that video will be out EFIGuy? Im not in a rush, as this is a full rebuild of every system on the truck. And Im just done the body so I have time!
D
Datch
St Albert, Alberta
Thanks Steve83, I agree that the nicest feature on the new cruise control like the Explorers is that ability to increase or decrease speed 1mph so easily! I guess I will spend some time and look for a location to install the components now.
wsager
If I remember right, those mustang controls were on the steering wheel. Looking forward to EFIGUY's write-up/video. That method really would open up switch possibilities.
