broncochevy
Hello all, been watching mostly and using search a lot but now I need some help. I purchased a 96 explorer with 5.0L and awd several months back from a member here and I’m just now tearing it down. Got the engine, trans and tcase out as a unit and separated the engine off the rest. My plans are to eventually use the 4R70W and EFI starting out with the explorer long block with a carb until I get time/funds to make all the fuel injection electronics work. The explorer had 246K on it and that seems like a lot to me. The day I went to get it my BIL told me, “ you should have told me you needed an engine, I have one in a truck I’ll give you...” It is a 93 with 5.0L, believe that is a roller not positive. If it is in fact a roller, it does have way less miles and was well cared for, etc. planning on using short block from this pickup, explorer gt40 heads and front dress, and eventually explorer efi and auto trans.
So, if there is any faults in what I stated above, please enlighten me.
Also, if I can get all I want from this pickup with 5.0L, what else should I grab? I do know that the pickup was parked a while back due to a bad tranny, so that is out of the picture and it is a one tire fire 2x. Plus, I have already cloned a 77 bronco rear 9” with a pickup rear end, had Torino ends installed and used the explorer rear discs with it. Still collecting parts to do the Chevy disc swap up front, ford drone disc 44s around here are scarce so decided to go the Chevy route.
Oh, I know this doesn’t matter much, but all this is going in a 67 bronco.
