Wondering how tunable the stock ecu is on a performance engine. Gonna look into it.
Sounds like it can be tuned quite a bit with the right equipment and knowledge. Garry is the go-to guy around here, but I'm sure there are tuners around the country that can do crazy things.
Personally I'd support Garry any time I can, unless you just need it yesterday and he's too buried.
FYI, there are stand-alone ECM's available for us now too. Haltech, Holley/MSD and the Pimp-X from Stinger Performance sound like cool alternatives if you don't have a stock one handy, or don't want to disable a running vehicle while the computer is out being tuned.
The Stinger one is not inexpensive at $900-ish, but it's a Ford factory case with the Megasquirt internals that can be set up to run Speed Density, Mass Air Flow, with Distributorless Ignition, Coil-on-plug, boost and a lot of other things. Including controlling an automatic transmission.
So while we have more options than we've had in a very long time, use EFI-Guy when you can.
I'm not there yet, but sure am bummed that when I finally settle on a distributor (Holley/MSD e-Curve) they now have a Coil-Near-Plug system for us! Figures...
