My 97 has a PCM code of XDT2. I want to grab another PCM at the JY so I can send both to you at the same time. Does XDT2 interchange with any other PCM codes?
Thanks,
XDT1-XDT3, or INJ0.
I will keep EGR, but removing EVAP.
So I guess VSS should stay. However, I wonder where to plug it in a manual transmission?
Yes I am taking the entire firewall harness. Not under the dash harness.
Do I need ignition switch and key assembly?
The engine will go into W123 Mercedes, not a bronco.
Thanks you
If it's a Ford m/t with provisions for a speedometer, then use a Fox Mustang VSS. Some later transmissions may have a VSS already. No need for the ignition switch components.
